Got some beef for my rear!
Old Jul 8, 2009 | 04:16 PM
Atomic's Avatar
I have a gauge for that
Default Got some beef for my rear!
ha.
I am tired of seeing this every time I walk to my truck even after replacing the pinion seal (which I thought was the problem),
So I got this,
Thing is beefy. 3/8" flange with 1/4" cover and weighs about 15 pounds. The stock cover is what, 1/8" stamped aluminum and weighs 2 pounds?
now to get it painted. I hope this fixes that damn leak.
And before anyone says I put the stock cover on wrong. I noticed the paper gasket was leaking when I first installed it so I took that one off and put some black rtv around it and put the cover back on....still leaked, so I took it off again and put a 1/4" thick layer of rtv all the way around making sure it was smooth and uniform...and it still leaks...
Old Jul 8, 2009 | 04:21 PM
GMCtrk's Avatar
Is that the high temp RTV? The one on mine is orange RTV and seals perfect. Also, did you confirm that the sealing surface is perfectly flat?
Old Jul 8, 2009 | 05:17 PM
Atomic's Avatar
Yep, the black is the oil resistant and hi-temp. mating surface on the housing is perfect.
Old Jul 8, 2009 | 05:31 PM
Breeze's Avatar
11 Second Truck Club
Looks good hopefully that fixes the problem.
Old Jul 8, 2009 | 05:51 PM
KySilverado's Avatar
Looks like the leak is originating on top of the housing. Have the vent tube on it?
Old Jul 8, 2009 | 06:48 PM
Atomic's Avatar
Yep. I was using 3/8" which is actually too big. Just replaced it with 5/16" which is the correct size at the same time I replaced the pinion seal.
Old Jul 8, 2009 | 07:18 PM
viciousknid's Avatar
Where's the Beef?
I knew you liked beef in your rear.
Old Jul 8, 2009 | 07:56 PM
Atomic's Avatar
haha i was wondering if anyone would get it, hence the "Ha" at the beginning.
Old Jul 8, 2009 | 09:03 PM
black06's Avatar
Grey rtv is the only silicone I have used to seal rear covers...no gasket
Old Jul 8, 2009 | 09:30 PM
ChevyTruck's Avatar
something else
Damn that thing is beefy! Where did you get that at?
