got a problem guys
Old Oct 24, 2007 | 03:47 PM
95ImpSS's Avatar
formerly 1BADC10 (12/14/2011)
do what was suggested with pulling a line to the aux cooler and start the engine. if the pump works properly, you'll have fluid pumpin' out. make sure you have a bucket and a buddy to help ya with this.
Old Oct 24, 2007 | 04:15 PM
thunder550's Avatar
High on diesel fumes
Originally Posted by MGMC
the converter was filled up before it was put in, and i added about 3 quarts to the tranny before starting. i can feel it click when i put it in gear, so i dont think the linkages are suspect. i remember when i was removing the tranny, there was two hardlines up top that no fluid came out or anything when i took them off. is there only fluid going through those when everything is on? i figured some fluid would of came out or something from the cooler? could it be a pinched line? ill be rechecking all that stuff again tomorrow. transmissions suck!!
Three quarts doesn't sound like enough. Not sure what the capacities are, but I think I remember my 4L80E taking 14 quarts dry. Are you 110% sure that there's enough fluid in there? Low fluid level would cause everything you're talking about.
Old Oct 24, 2007 | 04:30 PM
MGMC's Avatar
12 Second Club
i will recheck everything tomorrow and let you all know what i find/happens. i appreciate it guys for all the info and suggestions
Old Oct 24, 2007 | 05:22 PM
MGMC's Avatar
12 Second Club
14 quarts? ****, the pan dosnt look like it holds more that 3-4 quarts, that would be awesome if that is the problem. ill find out tomorrow
Old Oct 24, 2007 | 05:33 PM
thunder550's Avatar
The pan doesn't, but there is a **** ton of fluid that ends up everywhere else in the trans. The converter itself holds a few quarts, and remember that there are tons of passageways and crap in the valve body that need to be filled. I'm guessing that once you started the engine the tranny pump sucked the pan dry. Your symptoms are pretty much identical to what happened to me when I forgot to fill my trans back up after swapping valve bodies.
When you check the fluid level, make sure you check it with the engine running and on a flat/level surface.
Did a quick google search and found this
Fluid Capacity: (approximate)
Dry: 7.9L (8.4qt) with 245mm converter 10.8L (11.4qt) with 300mm converter
Old Oct 26, 2007 | 11:12 PM
MGMC's Avatar
12 Second Club
well i added about 11 quarts so far and she woke up. thanks for all the help fellas . the truck feels awesome
Old Oct 27, 2007 | 09:56 AM
thunder550's Avatar
Sweet, glad you got it all figured out
Make sure you didn't overfill it too, 11 quarts sounds like a lot if there was already 3 in there.
Old Oct 27, 2007 | 12:37 PM
TheChronic's Avatar
+1
Make sure to check it with the fluid warm and the motor running.
Old Oct 27, 2007 | 03:01 PM
bluecajun5.3's Avatar
11 Second Truck Club
and in neutral on level ground.
BKnBLK05
Dec 28, 2015 08:52 PM
Go5.3tt06
Sep 12, 2015 09:29 AM
fillpot
Jul 26, 2015 07:21 PM
lxcoupe
Jul 21, 2015 02:12 AM
GM-only
Jul 19, 2015 10:48 PM
