Got my 4L80e rebuild kit and Edge Converter today (pics)
Old Dec 18, 2008 | 02:49 PM
  #21
vanillagorilla's Avatar
Dude, get an HD sprag in there. While you're in there you might as well. No sense in spending all that time and money just to have a stupid part like a sprag fail.
Old Dec 18, 2008 | 06:16 PM
  #22
kbracing96's Avatar
Who sells them? I thought the 99+ had the good sprag in them? I will put one in there, I just need to know which one. ANYONE???????
Old Dec 18, 2008 | 07:58 PM
  #23
Wilde Racing's Avatar
How do I change this text
There are two roller clutches, and one sprag.....
The Intermediate sprag comes in 16 or 34 element, obviously, you want the 34 element. There are some aftermarket companies make 36 elements, but for the cost, I'd have to roll one over first....
The other two roller clutches are the overdrive roller assy, and the low roller.
Not much to do with the low roller other than INSTALL it in the right direction
The overdrive roller has two versions, the later version is the one with the blue inserts. It was some time in 2001 when the 4l80e started getting the new design roller.....
Also IF you go to a new design overdrive roller, the overrun clutch and the overdrive clutch assy will need to be updated as well.....
Here is a dark pic for your viewing pleasure...
Old Dec 18, 2008 | 08:59 PM
  #24
kbracing96's Avatar
OK, I think I'll stick to what I have then. I don't plan on abusing it in over drive and IIRC Thunder broke the sprag and did up grade it and was something crazy like 600 bucks, but I think his broke from 1-2 shift being set up to hard. I'm going conservative on my shift settings
Old Dec 19, 2008 | 10:07 AM
  #25
http://store.summitracing.com/partde...5&autoview=sku
Hmm....not sure why it cost $600. Maybe he upgraded the drum assembly too, which sometimes includes the sprag.
Old Dec 19, 2008 | 10:14 AM
  #26
nonnieselman's Avatar
SO you have all your parts together yet?
Old Dec 19, 2008 | 10:18 AM
  #27
FWIW, you can roll a sprag if you let off while spinning through 1st gear and the tires grab real hard. Like doing a burnout in 1st gear or somthing. That's probably the most common case of a rolled sprag. You might not have to worry about it, since you 4wd guys don't know how to do burnouts.
Old Dec 19, 2008 | 10:31 AM
  #28
Now that i didnt know... kinda scary haha
Old Dec 19, 2008 | 10:45 AM
  #29
kbracing96's Avatar
Humm... Does anyone now if i have to change anything else to run this sprag? I feel like an serous newbie with all these questions about it, but I've never done anything to a tranny other then a shift kit before, lol.
The Overdrive sprag requires a lot of changing to run so I'm gona stick with mine. Oh and Vince, the Sept 07 built version of the Transgo shift kit I got DOES come with a new separator plate. I found that out when I opened the box AFTER I ordered a new one,
Old Dec 19, 2008 | 10:57 AM
  #30
BigCountryx's Avatar
run into this with the 34 el sprag as well?
