This is gonna be hard
Old May 16, 2007 | 10:32 AM
krambo's Avatar
Thats how I have done mine and two other 4wd trucks and an SSS, it WILL come off you just got work with it. Pull it all the way to the back dont support the trans at all so it dropps down, tilt the output of the tcase over to the pass side and wiggle like hell and it will drop down. There is a heat shield there that on my truck I bent up with a hammer to make it easier but I didnt do that on the other trucks and still managed to get it out and no leaks after I put it back in. Take my advice for what its worth but it does work.
I'll agree. On an 03 SSS, it is very tight but does come off as 1slow01Z71 stated. Once you find the angle, you will know what he is talking about. Take care not to bang-up the output shaft when you are doing this. I tend to get pissed off and try to muscle it off which is the wrong way to approach this. Good luck!
Old May 16, 2007 | 02:42 PM
moes04silverado's Avatar
Originally Posted by KySilverado
Tried that the first time I pulled the tranny. There wasn't enough room to pull the x-fer case back and off, clearing the output shaft.
KY - I had enough room to get the out with removing the t-case from the fron set of bolts...the trick is once its loose jack the tranny up as far as it goes and muscle it out!! its a bitch but can be done!!
Old May 16, 2007 | 03:24 PM
KySilverado's Avatar
Originally Posted by LARRY01Z28
when you putting it back in. ill come by and help if your pretty close to stanford ky. just shoot me a pm and if im in town ill help you out no problem.
Thanks for the offer Larry. I should be able to pull in a couple buds close by.
Old May 16, 2007 | 03:29 PM
Originally Posted by Wilde Racing
I'm sure you know this but harbor fright sells a trans jack that is pretty cheap. I have never pulled the t-case back off the 4l80e. Of course I do get to pull the f-ing torsion bar crossmember.....
Yeah I went to harbor freight and bought one that goes on your existing jack. Thinking I would pull the tranny out with the x-fer case attached. After getting it home and trying it out there was no way I was going to trust it with the the job. They had another that I think I saw a pic you posted using it. I am considering going to get it but really don't want to spend the money on it and I don't want to drop the torsion bar crossmember.
I have a plan to get it back in. Some muscle, 3 jacks and tie downs for safety will get it done.
Old May 16, 2007 | 03:39 PM
Originally Posted by moes04silverado
KY - I had enough room to get the out with removing the t-case from the fron set of bolts...the trick is once its loose jack the tranny up as far as it goes and muscle it out!! its a bitch but can be done!!!
Hopefully I won't have to go through this again after getting it back in again this time. If I do I'll try and split it forward the adapter. It sounds like its much easier to do it where I am but getting the seal good is more difficult.
Old May 17, 2007 | 08:34 AM
LARRY01Z28's Avatar
ok man sounds good. just wanted to let you knwo id help if i can
Old May 25, 2007 | 09:20 AM
Spoke with PI this week. The had cut open the TC and no evidence of anything physically wrong with the converter. They are basically going to modify the stator to improve mid range torque control.... and if it doesn't work basically told me I'm out of luck. Sell it and we'll help modify the stocker. Only explanation as to why it had worked fine for months and not now is wear to the TCC clutch causing a little bit of resistance until recently.
I crawled under the truck last night and put the transfer case and transmission together in preperation of putting it back together. There is no way in hell I am going to attempt putting it back in there as a single piece. I'm going to split it back apart tonight.
Old May 30, 2007 | 08:55 PM
Well I'm right back where I started.. Truck running. 4th gear still slipping but with the stock converter and yes a small drip of fluid dripping off the transmission mount. Didn't fix a damn thing.
Old May 30, 2007 | 09:00 PM
I had a similar dilemma except instead of replacing the trans stuff I replaced heads and lifters. Life's a bitch.
dsbodley
Nov 14, 2015 09:46 PM
03sierraslt
14
Oct 9, 2015 05:53 AM
JordanH
Oct 3, 2015 03:59 PM
Wolftrk99
Oct 2, 2015 08:17 AM
twake_410
Sep 25, 2015 10:09 PM
