Going from 3.42 to 4.10s Qs...
14 Second Truck Club
I would say Strange/US gear, Motive, AAM are all really good gears, but I would probaably go AAM first. As far as what bearings you will need, that last thread you linked to was about replacing just a carrier. If you are changing gear ratios those are different bearings. You will need at least a new inner pinion bearing, they can be hard to get off in one piece. You wont have to remove the carrier bearings though, they can stay in place. Personally I dont see why you wouldnt just buy the kit. You will need the pinion nut, pinion seal, ring gear bolts, pinion and carrier shims, inner pinion bearing and race, gasket, lock tite- those are all a must. By the time you buy all that seperatly you are only saving maybe $30-40, sometimes less. It would suck to have a rear go bad because of $30 worth of bearings. Install will probably cost between $250-350 unless you can get a deal.
Originally Posted by SmokinLM7
I've been told that with the master installation kit you have some bearings and other fittings that don't need to be replaced therefore are leftover. So what exactly do I need for the swap?
Cammed4ever
09-30-2015 03:38 PM
lycominghunter
26
09-25-2015 07:50 AM
