GMT900 axle in a GMT800?
Old Jul 20, 2015 | 09:59 AM
Mike454SS's Avatar
Default GMT900 axle in a GMT800?
I came across a good deal on a complete rear axle assembly from a 2009 Silverado 1500. I have not yet had time to measure everything to see if it will work in my 2005. Does anyone know if it will? I don't want to be cutting and welding everything, but I don't know if the leaf spring mounts and shock mounts are the same or not.
Old Jul 20, 2015 | 08:44 PM
1FastBrick's Avatar
Custm2500's Rude Friend
The shock brackets are different, but I believe they might work. I was told people have swapped from the 2 platforms which leads me to believe the Leaf springs would be the same width apart.
You will have to measure to be certain. Post back if you find out.
Old Jul 20, 2015 | 08:49 PM
Mike454SS's Avatar
My friend has a 2013. I'm going to park the 2 trucks next to each other when I can and compare.
As I understand it, the frames are basically the same behind the cab...so it "should" work.
Old Jul 20, 2015 | 08:52 PM
George C....'s Avatar
Formerly ScreamingL
I have 2006 3/4 ton leafs on my 2010 1/2 ton
Around 11 is when the 3/4 went wider leafs but 1/2 ton same
calsdad
Jun 14, 2023 11:07 PM
Alco
Jul 20, 2016 04:53 PM
03sierraslt
14
Oct 9, 2015 05:53 AM
2002_Z28_Six_Speed
Oct 4, 2015 01:34 PM
twake_410
Sep 25, 2015 10:09 PM
