GMT900 axle in a GMT800?
I came across a good deal on a complete rear axle assembly from a 2009 Silverado 1500. I have not yet had time to measure everything to see if it will work in my 2005. Does anyone know if it will? I don't want to be cutting and welding everything, but I don't know if the leaf spring mounts and shock mounts are the same or not.
The shock brackets are different, but I believe they might work. I was told people have swapped from the 2 platforms which leads me to believe the Leaf springs would be the same width apart.
You will have to measure to be certain. Post back if you find out. |
My friend has a 2013. I'm going to park the 2 trucks next to each other when I can and compare.
As I understand it, the frames are basically the same behind the cab...so it "should" work. |
I have 2006 3/4 ton leafs on my 2010 1/2 ton
Around 11 is when the 3/4 went wider leafs but 1/2 ton same |
