Gear selector shaft swap how to??
Old Jun 11, 2011 | 09:46 PM
chubbz817's Avatar
Question Gear selector shaft swap how to??
Does anyone know how to swap out a gear selector shaft from a fbody 60e to a truck 60e ???
has anyone made a sticky??
i googled and searched it on pt but i couldn't find nothing
Old Jun 11, 2011 | 09:53 PM
Lextech's Avatar
I doubt if there is a sticky for it anywhere. It is a very easy, straight forward swap. You do not have to drop the valvebody.
Old Jun 11, 2011 | 10:24 PM
chubbz817's Avatar
Ok how bout some directions I don't even know where to start lol
Old Jun 12, 2011 | 06:56 AM
Lextech's Avatar
I never gave it much thought---It is really easy.
1. Remove the trans pan.
2. Remove the "U" shaped spacer spring from the shift shaft from inside the trans.
3. Remove the shift shaft nut from inside the trans.
4. Push shift shaft outward---The detent "Rooster Comb" will detach from the shaft and stay in the trans.
5. Remove shift shaft.
6. It would be a good time to replace the shift shaft seal in the trans case.
7. Install the new longer truck shift shaft in reverse order.
Jeff
Old Jun 12, 2011 | 11:00 AM
chubbz817's Avatar
Jeff
Thanks that's really gunna help me out jeff
Old Jun 12, 2011 | 12:22 PM
Vince B's Avatar
One thing to add to Jeffs post is sometimes the shaft will not just pull out. What works well if you have an impact is to put a nut on the outside threads of the shaft. While using a file and spinning the shaft, file down any high spots that might be there from the internal nut being over tightened. This will be the area where the rooster is keyed to the shaft. HTH Vince
SloSVO
Aug 11, 2015 07:33 PM
iregret
Jul 27, 2015 10:32 PM
Ketis
Jul 23, 2015 12:37 PM
alex226
Jul 16, 2015 10:55 AM
MileHighSierra
Jul 12, 2015 12:23 AM
