Help with th400 Swap
Old Jun 9, 2011 | 03:55 PM
InsaneDomestics's Avatar
Arrow Help with th400 Swap
I'm gonna be helpin a buddy do a th400 Swap on his 04 Regular Cab SB, Just need some help along the way.
We already got the FTI th400 and a LS Specific Converter so as far as getting this to mount up all we have to do is make a crossmember correct?
I havent found out much about the differences in the Flexplates, what is all that about?
I know the Driveshaft will have to be shortened and all that jaz
(I think we got it covered)
How long of a Dipstick Tube is used?
And what about the Speedo?
I read something about the Speed Sensor from a 3L80 (PN8655291, 8655315) and a Connector (PN12085498)
If there is anything I left out that I'll need to know? Thanks!
Old Jun 10, 2011 | 08:49 AM
JoeyGC5's Avatar
You can try those speed sensor adaptors, I've used the Dakota Digital pulse generator and the front wheel speed sensor before in th350/400 swaps.
Lokar makes a flex dipstick that will work out well.
Old Jun 12, 2011 | 02:05 PM
Ok, Anything else I might need to know?
Old Jun 12, 2011 | 04:26 PM
Gadgetized's Avatar
What are you using for a converter? You might be able to get the converter made to match up with your flexplate. I'm not sure if a regular flexplate will work.
Old Jun 12, 2011 | 11:46 PM
jasond26's Avatar
I have done the swap and here is a list of stuff that I done that might help.
TCI flexplate has the bolt pattern and adapter to run old school converter.
I ordered my tranny with speed sensor installed, you can call any of the tranny sponsers and I am sure they will give you the part numbers for that.
I welded a plate on the back of my crossmember for the mount and just picked up a energy suspension tranny mount from autozone.
Used a Lokar dipstick.
Local driveline shop to shorten the driveshaft.
B&M ratchet shifter
Thats about it.
Bluecollar Hotrods
Jun 11, 2024 11:37 PM
XL7
May 5, 2022 01:48 PM
121
Jul 16, 2015 12:18 AM
ALynch
Jul 6, 2015 09:49 AM
