Gear change vs dyno #'s
Old Dec 3, 2005 | 10:24 AM
TurboGibbs's Avatar
Default Gear change vs dyno #'s
Does anyone know or seen any changes in RWHP #'s after doing a rear gear swap or tire diameter?
Old Dec 3, 2005 | 05:53 PM
Tractionless's Avatar
I've heard you get lower tq #s with a lower gear. (higher numerically). Not really sure about this though.
Old Dec 4, 2005 | 12:52 PM
TurboGibbs's Avatar
Anybody else have any insight?
Old Dec 5, 2005 | 09:17 PM
blk03's Avatar
I would think it is the other way. The few times I have dynoed, I have got a lower tq # compared to people with comparable engine mods. The difference being I have 3.23s and they have 3.73s or whatever.
Old Dec 5, 2005 | 09:24 PM
TurboGibbs's Avatar
That is exactly the results I would expect due to a higher numerical gear multiplies tq. The actual change would be very little i'd imagine, The main thing would be, on the dyno anyway, the lower rpm you are having to spin up your tires/wheels which would save some HP.
Old Dec 5, 2005 | 09:30 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Going to 4.10s from 3.73/3.23s increases your torque multiplying capacity do to having more leverage on the tires. Less rotating mass would also do the same for your rw numbers since you can feel in the SOTP difference with shorter tires or lighter wheels so that translates into faster times and in ANY 1/4 time calculator whether by E/T or curb weight it will tell you that you gained hp with a faster time if the weight of the vehicle stays the same.
Old Dec 5, 2005 | 10:40 PM
kbracing96's Avatar
MJ,
A chassis dynos will show lower numbers with high numericly gears because of drive train losses. It's like running your truck in 3rd gear for a pull then then running it in 4th gear for the next pull. 4th gear will show better numbers because there is less drive-train loss then 3rd because it is 1:1 where 3rd isn't. The difference to 3.73 to 4.10 will be the difference in drive-train loss, you won't see a difference from torque multiplication you will just run up in rpm faster. Next time your at the dyno give it a try and you will se what I'm talking about.
Old Dec 5, 2005 | 11:55 PM
brodystruck's Avatar
Third gear is 1:1...
Old Dec 5, 2005 | 11:58 PM
kbracing96's Avatar
Not in a 5-speed, which is what Mjhoward is running
Oobray
Jun 13, 2022 03:38 AM
thunder550
Oct 8, 2015 04:53 PM
Noah Burns
Oct 5, 2015 06:46 AM
Greatdivider
Sep 9, 2015 09:52 AM
NuckenFuts
Jul 9, 2015 08:45 AM
