Gear Change = ABS light
Old Sep 18, 2010 | 11:11 AM
ihdude's Avatar
Default Gear Change = ABS light
On my 4x4, I changed the gearing and now my abs light comes on sometimes. I am running 35" tires with 4.88 gears front and back. I have a wait4me tune that was suppose to be changed to those specs but I do know my speedo is off some. The dealer computer shows codes for the front abs sensors. I ran a little while with just the rear gears and I had no light until I changed the front gears.
Old Sep 18, 2010 | 11:44 AM
mhotrodscooter's Avatar
Maybe you broke a senors,or maybe you got a bearing getting bad!
Old Sep 18, 2010 | 12:07 PM
ihdude's Avatar
The ABS light doesn't come on all the time though. I would think if the sensor was cut it would be on all the time.
Old Sep 18, 2010 | 12:40 PM
If it started after you done the front, then somethings not right. If dealership said front that's where id start looking! Could be a bad connection,moister,broken wire etc.
Old Sep 18, 2010 | 02:55 PM
Cooder5.3's Avatar
When I did my gear change my ABS and parking lights come on after a little bit of driving. Once I got my Wheatley tune every went off and hasn't come on since.
Old Sep 18, 2010 | 03:46 PM
Atomic's Avatar
I have a gauge for that
Yea tune should take care of it.... sometimes you cant plug in 4.88 and the actual size, but you can do 4.10 and some other tire size that gives an equivalent relation.
Old Sep 19, 2010 | 10:33 AM
carolinaz71's Avatar
Yea don't feel bad I just did my gears, I have a wait4me tune as well. He didn't fix the light or set my speedo, he sucks I'm tired of dealing with him. He's a joke as a tuner and has horrible customer service, i'ma get a dyno tune as soon as I can afford it
Old Sep 19, 2010 | 02:11 PM
ihdude's Avatar
I agree on the wait4me tune. I don't have a dyno anywhere near me right now. I think I'm going with a Blackbear tune next time but I want to get a cam in before I do. I'm am concerned that the speed is off they way it is. If you didn't realize your speedo was off then it would appear you are getting better mpg than you actually are. Initially I had 33" tires and my speedo was off but dead on when I went to 35s. Now I had a gear change and my speedo is off again after I had it retuned. Is there anyway to check and correct that?
Old Sep 20, 2010 | 11:19 AM
Don't forget to check the grounding wires under the driver side frame rail. There is an ABS module that sits in the frame underneath you. I had the ABS light pop on and it turned out to be a grounding issue with this module. Just a suggestion but it helps to check everything.
Oobray
Jun 13, 2022 03:38 AM
ARC
57
Feb 21, 2022 10:54 AM
Ketis
Jul 23, 2015 12:37 PM
bsgiffor
Jul 19, 2015 11:14 AM
1320Chicken
Jul 14, 2015 10:58 PM
