G2 cover load bolt torque??
Old Jul 20, 2016 | 11:29 PM
Wolftrk99's Avatar
Default G2 cover load bolt torque??
Anybody know the torque specs for the g2 diff cover/girdle load bolts??? figured they would include a piece of paper in the box somewhere that has specs or maybe even an instruction sheet, but.... Nooooo! My luck, i get a cover, a bag of 3/8 bolts, a tube of black rtv, and a piece of bubble wrap!! I plan on buying a cover gasket, as i dislike using rtv unless absolutely necessary, and a set of 8x1.25 bolts. I am assuming the bolt torque for the cover itself is the same as the factory bolts??!!
Old Jul 23, 2016 | 12:22 PM
Wolftrk99's Avatar
Anybody?
Old Jul 23, 2016 | 12:46 PM
07Softail's Avatar
Moser covers use 5 ft lbs for load bolts and 25 ft lbs for the cover screws. Not sure about G2 though, it should be close to that I would think. hope this helps
RT
Old Jul 23, 2016 | 01:44 PM
Wolftrk99's Avatar
Thanks, something to start with anyway... I am going to try to get the cover installed tomorrow....
Old Jul 23, 2016 | 11:19 PM
1FastBrick's Avatar
Custm2500's Rude Friend
RT
TA Performance recomends the same on the load bolt. I believe they manufacture most of these style cover out there for most companies.
Old Jul 23, 2016 | 11:25 PM
Wolftrk99's Avatar
I noticed alot of the diff cover/girdles look like the ta girdles... Called 4wheelparts today the national call center was a waste of time, the local store said same thing, 15ft lbs 1st pass 30ft lbs second pass on the cover bolts and 5ft lbs (60 inlb) on the load bolts... Its supposed to be hot as hell here tomorrow and monday so i dont see work being very busy tomorrow, so i should be able to get this and my new to me tire on...
Old Jul 23, 2016 | 11:40 PM
1FastBrick's Avatar
I had to give up today because of the heat and humidity... Too much for me to handle.
Old Jul 24, 2016 | 12:10 AM
Wolftrk99's Avatar
I have every intention of doing the same tomorrow about 3-4 pm.... Figure 6 hours in 107* heat will be plenty....
brandonrac15
Jun 3, 2016 04:16 PM
B&M Racing
31
Jun 2, 2016 10:23 AM
01SilveradoJakee
May 18, 2016 06:38 PM
Jake75
May 17, 2016 01:11 AM
