Full Spool for 8.6" Rear ends?
Originally Posted by onebadrubi
yes rhino from what I hear auburn wont be that much better then the G80 in the higher HP numbers.
Its a bad idea if you have drum brakes. Spools can break a axle fairly easily. In drum brakes, when the axle breaks it goes shooting out the side of truck tire and all. When a disc brake axle breaks the caliper keeps it from going anywhere. Of course C-clip eliminators and such will help prevent all that. I used to daily drive a mustang with a full spool. Lots of fun but be careful.
Any info helps thanks in advance
You'll probably just start breaking something else once the spool goes in. Off road **** helps cause traction is usually non-existent, but based on your typing it sound like you just need to save up for a simple 9" swap. Just my .02
TimDave217
Aug 24, 2015 04:38 PM
shupe
Aug 5, 2015 06:45 PM
