front suspension rebuild
Old Jul 29, 2016 | 01:11 PM
terravast4's Avatar
nice. thanks for all the info. I'm gonna upgrade to the wildwood 16" brakes up front too.
Old Jul 29, 2016 | 01:26 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
If you flip the upper control arms, your upper ball joint angle will improve, and they will last longer. Just gotta press the ball joints out & then back in from the other side.
Old Jul 30, 2016 | 11:25 AM
terravast4's Avatar
thanks AK.
Old Jul 30, 2016 | 12:40 PM
terravast4's Avatar
im guessing you need a coil spring compressor since this will be completely apart?
Old Jul 30, 2016 | 12:54 PM
Tig's Avatar
Tig
What exactly does this do? I'm a little confused.
This is for a lowered application, correct?
And will it work for an 07 Tahoe? I have the alignment bushings.
I'm getting ready to drop mine and will be replacing pretty much everything, like the OP. I'd like to convert to coil-overs soon after my drop.
Thanks
Old Jul 31, 2016 | 05:41 AM
madmann26's Avatar
For safety reasons, yes.
However, you can do it with a large floor jack.
Put the jack under the LCA after you remove the shock. Take the LCA bolts out and lower the jack slowly.
The truck will need to be fairly high to do this.
Old Jul 31, 2016 | 10:32 AM
terravast4's Avatar
i saw a video of that. i don't trust that. id rather get a compressor
Old Aug 3, 2016 | 02:41 PM
Tig's Avatar
Tig
Thanks
I found the answer for this.
Flipping the control arms is for 00-06 model years.
NORCAL TBSS
Aug 25, 2016 05:14 PM
2014ALLTERRAIN
Jul 22, 2016 05:13 AM
gtojustice
Jun 15, 2016 09:51 PM
blownss06
Jun 15, 2016 07:23 AM
willhorne22
May 12, 2016 07:38 AM
