front limit straps
Old Apr 13, 2010 | 08:01 PM
TURBHOE's Avatar
Default front limit straps
who has used them and how did you make them?
i'm trying to get a better 60ft but my front lifts so much it unloads the front end, and it tries to send me into the wall. i got a 1.89 i think was my best. but i'm holding the wheel 90* to keep going straight. and my front right tire tends to lift and freewheel. so there is lost power there. i know i have a 5.3l high 11 run in there on a cool night with a good straight 60ft.
Old Apr 13, 2010 | 08:20 PM
RibeiroBJJ's Avatar
Praise The Lowered
I bought some here in San Diego at ORW (off road warehouse) for my 04 AWD Silverado SS..They were for offroad trucks and available in a bunch of lengths...I think I used 12"...I used 1/2" grade 8 bolts and drilled through the control arm and frame...worked really well. I was actually able to pull a 1.67 with them on...Summit or Jegs should also have em..Good Luck!
Old Apr 13, 2010 | 10:53 PM
TURBHOE's Avatar
a 1.67, with how much power?
Old Apr 14, 2010 | 05:33 AM
stock48's Avatar
9 Second Truck Club
With all that transfer I think you would be better off running 2wd with DR's on the rear. The only way your going to eliminate the transfer is by strapping the front down, and stiffen up the rear. Some adjustable rear shocks set on stiff would help wonders at the drags.
Old Apr 14, 2010 | 01:18 PM
TURBHOE's Avatar
straps are cheaper than an axle....... remember i've broke two axles with this thing in 2wd. i'm not gonna chance it again. no matter the argument I'm not willing to prove people wrong with my wallet. lol that's refereed to the people that think my detroit locker weakened the axles. even though one was only in there for like a week before i broke it.
didn't mean to rant.
Old Apr 14, 2010 | 02:00 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
I went from 1.62 60's to 1.57 with straps. Custom made by Synergy using cables but same thing basically, adjustable.
Old Apr 14, 2010 | 03:08 PM
charcold-bowtie's Avatar
link
here is a thread i remembered
Old Apr 15, 2010 | 01:20 PM
TURBHOE's Avatar
i'd like to know how well the truck rides with the straps on.
Old Apr 15, 2010 | 01:37 PM
trever1t's Avatar
same amount of compression way less rebound=nose down and steady.
Old Apr 15, 2010 | 04:47 PM
1Bear's Avatar
Agreed, I didn't notice any change in my ride at all. The only way you could notice a change is if the truck went over something hard enough to cause it to bounce. Every time you hit a normal bump, it will just add slack into the straps and things just go as normal.
