GMT800 driveshaft options, will be shortened
Old Jul 29, 2015 | 10:45 AM
tgui's Avatar
Default GMT800 driveshaft options, will be shortened
I'm getting a new driveshaft for my 02 Yukon. Direct model year fitting ones are always rusted to ****.
I'm going to be shortening the driveshaft for a 4l80e swap.
Seeing how length isn't an issue, will newer year GMT900? fit yoke wise? The newer driveshafts look stronger, larger diameter and seem less prone to rust.
Old Jul 31, 2015 | 09:53 AM
1bad2k's Avatar
You can have a better one made from scratch. All fresh and new!
Old Jul 31, 2015 | 10:58 AM
Atomic's Avatar
I have a gauge for that
There is not much clearance between the stock shaft and the trans so I dont think a larger diameter will fit. I had a stock diameter one custom made that was thick wall steel and used the factory yokes.
Old Aug 10, 2015 | 09:29 AM
TURBHOE's Avatar
did you use the stock harmonic piece on the front yoke?
Old Aug 10, 2015 | 11:37 AM
tgui's Avatar
I plan to. I'm slightly ignorant, should I not?
The Ebay driveshaft and new ujoints are in transit. Once I have it in hand I'll get it shortened.
I'll be sure to post the final product when I have it all in hand.
Old Aug 10, 2015 | 12:25 PM
TURBHOE's Avatar
from what i understand, you want to keep it. the shaft is short so that helps keep it running smooth.
Old Aug 11, 2015 | 08:30 AM
tgui's Avatar
Ahhh, good to know!
calsdad
Jun 14, 2023 11:07 PM
thompson
Dec 27, 2017 06:48 AM
turbo6c3
Oct 5, 2015 06:11 PM
jscherbs
Sep 30, 2015 07:54 AM
Closer_2001
Sep 24, 2015 09:15 PM
