Front Differential Gear Ratio?
Old Dec 27, 2006 | 10:31 AM
KySilverado's Avatar
Default Front Differential Gear Ratio?
Is there anyway to determine gearing in front diff from a part # 63WH2GP005677
Old Dec 27, 2006 | 04:55 PM
Mort's Avatar
Cool
Hold one axle fixed and turn the other. Mark the input shaft and axle and count the turns with one full rotation of the axle. If the input shaft rotates 4.1 turns approximately to one full turn of the axle then it has 4.1:1 gears.
Sorry not sure about the part # indicating the ratio.
Old Dec 27, 2006 | 05:28 PM
Trying to buy one. Wanting a 4.10 ratio. Guy has one on ebay but doesn't know the ratio. All he gave me was that number.
I sent him another mail asking him to do just as you describe yesterday. So far he hasn't replied.
Old Dec 27, 2006 | 05:41 PM
jblack6527's Avatar
Is it just the gear? Or is it in the housing? It should say on the gear, if its in the housing, just have him pull the cover and look. If for some reason its not stamped on there, all he would have to do is count the teeth.
Old Dec 27, 2006 | 06:24 PM
Its a complete front 8.25 differential. NOS, never installed. You have to split cases to get to the gears in an 8.25.
Old Dec 28, 2006 | 05:05 AM
jblack6527's Avatar
ahhh, did not know that. I guess then the only good way would be what mort suggested. Maybe you could call GM? I dont know if they could tell you or not.
Old Jan 3, 2007 | 12:20 PM
Well I've bought a differential and have it in the garage. It was advertised as a 4.10 ratio but I want to verify it before I put it in. As it sits and just spinning the input shaft neither axle spins so I can't do the count rotation method.
I am thinking I can put power to the electric actuator and do this. Does anybody have a pinout for the actuator?
Bluecollar Hotrods
Jun 11, 2024 11:37 PM
chopperloco
Jul 10, 2016 10:45 PM
thunder550
Oct 8, 2015 04:53 PM
Noah Burns
Oct 5, 2015 06:46 AM
Ketis
Jul 23, 2015 12:37 PM
