Front dif noise
Old Feb 25, 2006 | 06:46 PM
stingragtiger's Avatar
Default Front dif noise
Ok guys, My front dif is making a noise similar to a u-joint going bad, however it's coming from the front dif and not the u-joints. No feed back at all thru the steering. It makes the noise no matter if it's in 4 wheel or 2 wh.
Changed the fluid a few times and some shavings nothing unusual. Any ideas? thanks in advance.
Old Feb 25, 2006 | 07:22 PM
Check the driver side axle flange, you might have a worn out bearing. I have seen this happen on a 94 3500 4x4 but never on a NBS truck. It could also be the outer cv joint.
Old Feb 25, 2006 | 07:52 PM
RoninsDenali's Avatar
I had my carrier bearings disintegrate Atleast thats the word the Tech used when he discribed it to me lol. But thats where all the metal shavings in the fluid came from, all the gears where fine so chances are you got a bearing on its last leg.
Old Feb 25, 2006 | 07:56 PM
Just so you know I can spin the tires jacked up and no noise. IT only happens when in 4wd on the lift. It has been making the noise for a few months, so I'm thinking It has to at least be a fairly thick or big part. And by the way my gas mileage hasn't changed. Thinking the engine isn't working any harder than normal.
Old Feb 27, 2006 | 06:59 AM
anyone have anyother ideas???
Old Feb 27, 2006 | 11:21 AM
z7199's Avatar
I have a 3.73 front axle I will sell cheap it works great but does need new seal on the case Here is the link to mine it is the older one with the oil. I think all it really needs now that I think about it is a pinion seal like 15 dollars from GM I belive. nothing wrong with it just went to 4.10 and got a deal on a whole axle. http://www.cardomain.com/ride/456511/6
black03rcsb
Sep 1, 2015 10:17 AM
superchomper2003
Aug 26, 2015 09:39 AM
GRRR65GTO
Jul 10, 2015 08:27 PM
Breitling
Jul 6, 2015 06:39 PM
Breitling
Jul 6, 2015 04:50 PM
