FLT Level7 is finally here!! **PICS**
#52
PT's Slowest Truck
Glad to see the progress. Man, I dont miss pulling those 4wd transmissions. HOW the HELL did you get those torque converter bolts out without ******* something up? I ended up stripping them all out, breaking a brand new allen socket, then tried welding a nut to them only to break the crappy welds off. Guess the heat was enough and I was able to finally channel lock them out without killing my knuckles.
Usually the first time the trans drops, I go ahead and break that NSS. They still work, just a little broke
GM glues the plugs in there for some stupid reason. I hear you can heat them up with a hair dryer, but didnt think of that during my converter swap.
Now, Quit screwing off, go get that thing running
GM glues the plugs in there for some stupid reason. I hear you can heat them up with a hair dryer, but didnt think of that during my converter swap.Now, Quit screwing off, go get that thing running
Originally Posted by tdrumm
Nice progress Billy, I was wondering how it was going all day yesterday. I got called into work yesterday after Gavin's baseball game, which killed my opportunity to stop by.
I say go for the tent today, and if anyone gripes, just tell them if they want it done today, then this is what it will take, so **** off.
Originally Posted by fastnblu
It's the only way. If u overbuild, when time comes, it won't have be done. Or at least done again, that's the plan right?
Originally Posted by white1
You not done yet?? WTF??
#53
PT's Slowest Truck
Ugh, gotta take a break, think I'm done for the day...got a lot done, but I'm not done. The damn u-joints are not cooperating...think that I'm going to have to bring the driveshaft to work and use the press...the whole set up wouldn't fit in the vice, so I tried big c-clamps which didn't work, tried whaling on the cups with the air chisel and a blunt bit, no dice, tried hitting the cups from the inside with a hammer and a punch, won't even budge. I used my torch and melted all of the plastic stuff out of the little holes (that was pretty cool), and was just able to get one of the new u-joints into the new yoke with a c-clamp.
All that's left at this point are the u-joints and install the driveshaft, y-pipe and cat back, swap in the new pcm, fill the t-case and trans, run it and check for leaks, re-install the grille and lower splash shields, and enjoy! Guess it will have to get finished up this week after work...I'll bring the driveshaft to work tomorrow.
I took a lot of pics of the transfer case and t-case install, trucool install, and whatever else I did today (so burnt at this point that I don't even remember), I'll post them up later, the camera is in the garage somewhere...
I'm a little bummed as I was hoping to drive the truck today, but I've waited this long, what's a few more days...surprised the swap is taking this long, I used to be fast lol, guess I'm getting old
#54
Nice progress though. Man whats the temp up there? Its like 95 here in southeast texas and I was about to go out and do my trans gauge install but i'd roast.....
Did you notice any slack in the chain in that transfer case? I have a clunk when I go in reverse, and I've kinda narrowed it down to T-case....new u-joints, the rear end looks sound....It sounds like its right under where the t-case would be.
#55
And as for your clunk, have you packed the slip-yoke with grease? That was a major "issue" on these trucks.
#60
PT's Slowest Truck
Yea, the weather was nice today, a little humid, but not too hot...especially since it was supposed to rain. The transfer case chain did seem to have some slack in it, but I believe that's normal. As Dan mentioned, the slip yoke is the major clunk and clang. It has been revised with a nickel plated one, which is what I was trying to install today but the u-joints were busting my chops
Here's what I did today...
The original clip that's prone to breakage...mine was OK, but I'm glad that I replaced it anyway
The redesigned clip that slips on to the pump
Clip part number
If you decide to do this repair, pay special attention to the pump pickup screen, mine was totally clogged with the excess case sealer from when the t-case was assembled at the factory:
This is the sealer that the dealer sold me when I asked them what they used to seal the t-case
Wrestling the t-case around is a bitch, so I came up with an idea to give my buddy and me an extra hand
The EAD brackets for the TruCool 40K, painted flat black
Trucool installed
A look at the lines and compression fitting, and slots cut into the little plastic shield to accommodate the lines
SnapOn 14v 3/8 cordless impact gun...this tool has been invaluable throughout this job...I was able to break just about every bolt loose except the 18mm crossmember bolts and the top bellhousing bolts that needed long extensions
Casualty of war...SnapOn dead blow that blew apart trying to get u-joints out
Clip part number
Trucool installed
