FLT Level7 is finally here!! **PICS**
#61
hey could you explain a little more on what you used fittings wise for your tranny cooler lines to get them to fit up to the cooler. What cuts did you make to get the hard gm lines to fit up so nicely? also where did you get the EAD brackets? thanks!
#62
PT's Slowest Truck
#65
The kit with the compression fitting and adapters plus mounting brackets is def worth the money!!! Makes it much easier. Setup looks clean with it.
However, i did find that the bottom mounting bracket i got was cut wrong. The hole for the ambient air temperature sensor, was on the left side and not the right. I just mounted it on the rubber mat under the cooler, no big deal but found it odd that the hole was on the wrong side haha
#67
Hell pecker yeah man! its looking good. working in the parking lot is a bitch, i had to pull the heads on my old dakota R/T in the parking lot of my complex once. that drivetrain will be damn near bullet proof!
#68
Also, install on your 40K looks sweet. I like how clean it mounts, flat black matches better than a semi gloss.
However, I don't like the extra cuts in baffle even if it's hidden. Nice work! BTW, you're not gettin old, u are.
Dead blow hammers. Do Not leave those out in the cold!!! Bring em inside over winter. Trust me on this. Already replaced 1 this winter that shattered, now another has to go back left out. Unless, u were man-handling it like a beast.
#69
