flip installed but has issues?
Old Jun 19, 2014 | 03:48 PM
  #31
ecir45's Avatar
Measure driveshaft angle first then jack truck up to just get the driveshaft off. Then dropped her back down to take measurements if possible. with my 3 5 drop I can just squeeze under the truck but it was still rough maneuvering to see reading.
When you have driveshaft off feel the endplay of the pinion in the reared to make sure it isn't excessive.
Old Jun 19, 2014 | 04:12 PM
  #32
stroker87's Avatar
yeah thats not going to happen with me LOL
i'm thinking jack it up from each side to get the stands under it.......
this is a 6.0L/4l0E swap and I'm thinking the trans mount is to tall "or" to short for my truck?
Old Jun 19, 2014 | 04:36 PM
  #33
ecir45's Avatar
That thread I referenced earlier has good tips.
LS1TECH - View Single Post - pinion angle... ive read everywhere and no help
Old Jun 20, 2014 | 01:12 PM
  #34
ecir45's Avatar
I downloaded the Clinometer app mentioned in that thread and man its pretty cool and easy to see and read.
Old Jun 20, 2014 | 07:10 PM
  #35
Lilbro's Avatar
From: Right of the rock and left of the cactus, Arizona
I did a flip kit, shift kit and 4.10 gears. My drive shaft VIOLENTLY hits the trans tunnel. Spring wrap sucks on these trucks.
Old Jun 21, 2014 | 02:08 AM
  #36
stroker87's Avatar
how low are you? yeah i'm going to build me some long bars hunting info the last few days to stop the wrap
Old Jun 22, 2014 | 12:23 AM
  #37
Lilbro's Avatar
Just a touch-
Old Jun 22, 2014 | 02:05 PM
  #38
stroker87's Avatar
ok so a re-measured this time I set the E-brake so nothing would move lifted one side at a time (set a camera to see if ant thing changed all good)
the trans is 7.2 degree's down the diff is 0.2 degrees down with the 6 degree shims
so since there suppose to be equal but opposite on paper if i pull the shims out that should put me right about 6 degree's up witch would have to about 1 degree difference but when I didnt have the shims it was worst?
Old Jun 23, 2014 | 07:35 AM
  #39
ecir45's Avatar
6 degrees was too much and nothing probably not enough go with what Brandon6 said earlier in the thread with a 2 degree shim.
https://www.performancetrucks.net/fo...0/#post5220565
Old Jul 3, 2014 | 08:18 PM
  #40
stroker87's Avatar
well i think I fixed the problem so I thought I'd update this
I've played with shimming the axle, taking every thing apart to make sure it was all put back correct and still had that clunk noise so I did the only thing I have not done at this point installed about 1/2 thick plate under the tail shaft of the transmission to raise it up so far no clunk and only took it in a short drive up to 65mph no shake or vibration
So I guess I'll see over the next few days.......... Hope it solved I'm tired of dealing with it
