ECSB 4WD 4l60E to 4l80E
Old Apr 3, 2014 | 12:00 PM
  #391
Ferocity02's Avatar
Originally Posted by nickleahy23
Anyone got a number or link to buying the 2 pins that go into the connector at the computer? Having trouble finding them for the sensor wire. Thanks.
If you use this method there is no need to run new wires to the PCM for the ISS: https://www.performancetrucks.net/fo...7/#post5092887
But I think the pins are Delphi 12084912. Mouser has them for cheap.
https://www.performancetrucks.net/fo...m-pins-366008/
  #392
timmay208's Avatar
i want to say the PN's were posted in this thread, im trying to find the company i bought mine from but i cant remember
Old Apr 3, 2014 | 01:14 PM
  #393
nickleahy23's Avatar
Awesome. I knew I had seen that somewhere. So basically just remove both of those pins from the green and blue, and replace them in to positions 22 and 23, crimp my new ISS connector to them out of the trans plug and im set, no extra wires.
Old Aug 10, 2014 | 07:12 PM
  #394
NuckenFuts's Avatar
This is for sure one of the best write ups I have read and have just a few questions to get answered as my 80 shows up tomorrow.
What tranny line can I reuse from my 60, Top or Bottom? (was asked on page 31 but no response)
What are you guys using to extend the other line to work with the 80. I see the 2500 Tranny line #15812029 is like $22 and dont know if thats the better way to go then getting compression fittings / Hose and longer rear 80 fitting. (if I replace the full line where does it go to on other end, Radiator or Cooler?)
Will my starter in my Lq4 work just fine with a 6.0 Flywheel now as it does have that spacer on it? ( starter is from my 5.3 that i used 5.3 flywheel on Lq4 and have to change over to lq4 flywheel)
Thanks For any help and cant wait for my new 80 and 3600 stall.
Old Sep 25, 2014 | 03:40 PM
  #395
V-seriesTech's Avatar
Originally Posted by 04likearock
has anyone notice how much more the 80 takes to move the truck
Umm, what?
https://www.performancetrucks.net/fo...esults-503358/
Old Oct 14, 2014 | 10:07 AM
  #396
TURBHOE's Avatar
When you do an 80e swap. Which sensor runs the speedo? I'm trying to help a guy out, he did the swap and now has no speedo but they are all hooked up.
Old Oct 14, 2014 | 10:18 AM
  #397
03sierraslt's Avatar
The rear sensor.
Old Oct 15, 2014 | 08:34 AM
  #398
TURBHOE's Avatar
Ok that's what I thought. Thanks.
Old Oct 15, 2014 | 11:59 AM
  #399
Hope his trans had provisions for rear vss.^^^^
Old Oct 15, 2014 | 12:11 PM
  #400
Atomic's Avatar
I have a gauge for that
All 80es have rear vss sensors. With 4wd you can either use the one in the tcase, or the rear one in the trans. However, I would use the one in the tcase because of 4low. If you never use 4low then you can use either.
