ECSB 4WD 4l60E to 4l80E
Old Sep 21, 2008 | 04:33 PM
  #31
Grumpy5.3's Avatar
This is a good thread, but your shop/garage is the cleanest of any of them I have seen.
Good Job!!!
Old Sep 22, 2008 | 07:23 AM
  #32
nonecktribe's Avatar
looks awesome so far...
Old Sep 25, 2008 | 07:00 PM
  #33
KySilverado's Avatar
Good Job!!!
Seems I always get comments on the garage when I do these write-ups. The floor does get cleaned/mopped regularly. Its where the dog stays during the day and he leaves a mess I don't want to lay in
Old Sep 25, 2008 | 07:02 PM
  #34
Well the shifter bracket is a go.
Old Sep 25, 2008 | 07:06 PM
  #35
have you found out if you have to purchase more credits to do the segment swap thats all i like im done with mine i just need to get the program and drive it.
Old Sep 25, 2008 | 07:17 PM
  #36
Starting the Trango install.
Don't think I got the latest kit.
A shot before I start touching anything.
All the solenoids electrical unhooked. Bolts removed. Etc... ready to pop off the valve body.
A picture for the check *****. This is the case under the valve body.
Underside of the valve body. Good shot of the the accumulator piston housing.
The piston housing, plate and gaskets removed from the valve body.
Should I be concerned with plastic pistons in the 80E?
More to come!
Old Sep 25, 2008 | 07:18 PM
  #37
Wish thats all I left to do!
The fine folks at HPTuners did a segment swap on my file. No additional credits required.
Old Sep 25, 2008 | 09:48 PM
  #38
Step by step of the Trango Install:
Step 1
Drill a hole. EDIT: THIS HOLE IS TO SMALL. CORRECTED LATER IN THREAD.
Step 2.
Remove a valve and place some springs and new end cap. Both springs lightest shift. Outer spring only firmer shift, inner spring only firmest shift. I'm going light this time around.
Step 3:
Remove filter and plug. Remove the o-ring from the filter. Install a tapered plug, the filter and orange spring. Directions say to grind some off the filter if it all doesn't fit. I may be doing that after looking at it again tomorrow. It doesn't fit.
Old Sep 25, 2008 | 11:10 PM
  #39
who did it for you ill post pics up tommorow but the yoke from the 2500hd worked perfect i just bought a precision #447 bastard ujoint and i didnt have to cut the yoke or nothing direct bolt in well beat the hell out of the old ujoint to get this new ujoint in but im needing a tune bad cause now its just sitting there it cranks lol.
Old Sep 26, 2008 | 08:21 AM
  #40
Contact bill@hptuners. He should be able to help with the tune.
The 2500HD yoke isn't an option for me without swapping the output shaft of the transfer case. 32 spline I am assuming. Mine is 27 I think.
