ECSB 4WD 4l60E to 4l80E
Old Mar 27, 2011 | 07:17 PM
  #311
McAllenSS's Avatar
Great write-up! I have the 246 autotrac, could I follow this write-up as directions on how to complete the swap??
Old Mar 27, 2011 | 07:28 PM
  #312
TIM Z's Avatar
11 sec. Truck Mod
Im not sure if i missed it, by why isnt this thread a sticky in the drivetrain section?
Its a damn epic thread!
Old Apr 4, 2011 | 08:19 PM
  #313
david0982's Avatar
I want to do this to mine!
Old Jun 10, 2011 | 07:10 PM
  #314
iregret's Avatar
Charlie Murphy!
I just read the entire 32 page thread. I just wanted to say thanks for making it. Also thank you for maintaining all of your pics. I'm so glad I found it. I've read quite a few threads for swapping into a 2wd, not much for the 4wd.
Thank you.
Old Jun 10, 2011 | 11:08 PM
  #315
swift700's Avatar
I followed the thread to a "T" and all of the info is good . There are a couple of tidbits that might help. To avoid crossmember to TCCM interference, I cut the center crossmember section a little shorter, 5 1/2 inches from the bolt holes. Also, the brake master cylinder level plug will fit the VSS of the 80E. That one that dangles by the A/C can is the wrong one. I did the 246 transfer case but had to change the input gear just like in this thread.
Thanks to the OP for the writeup, it was invaluable.
Old Jun 11, 2011 | 04:32 AM
  #316
Static54's Avatar
Maybe they could put this in the relatively new Write Ups Forum section.
Old Jun 11, 2011 | 12:59 PM
  #317
Bill Reid's Avatar
Thread moved to GM Drivetrain & Suspension and stuck! Good stuff!
Old Jun 20, 2011 | 08:40 AM
  #318
Emulsifide's Avatar
KySilverado,
I just wanted to say thank you for making this thread. I have a 4th gen Camaro that I'm swapping a 4l80e into. The info in here is priceless and is a TREMENDOUS help not only to you guys, but to the f-body community as well.
Here's my contribution to the thread. The reason the VSS wires are twisted is due to the potential of interference from something else on the vehicle. The twist causes the electrical fields emitted by the wires to cancel out as well as block outside interference from affecting them. The same technique is used on "twisted pair" ethernet that's connecting your computer to a router or cable modem.
Thanks again!
Old Jun 26, 2011 | 12:08 PM
  #319
pewterliftedz's Avatar
kysilverado on your first post you mentioned that you could replace the output shaft of the 4l80e to a 27 spline one.
does anyone know where to get one from.
nobody's been able to figure out how to join a MP3023 (the NNBS autotrac T-case) to a 4l80e due to input shaft issues. I think changing the output will be an easy solution.
they are 355 at transmission center dot net
anyone know another website???
Old Jun 28, 2011 | 12:49 PM
  #320
baxter2w2's Avatar
Registered User
so i found a 6.0/80E package out of a 02 truck, i have an 02 tahoe i wanna put it in. I have been playing with chevy stuff for a while now but not ls stuff so my questions are: i have a complete hardness/computer from the tahoe and the truck witch on is the better one to run? im going to cam up the 6.0 and run a few little bolt on, will i have to tune it right away? and last but not least i have the truck exhaust thats factory 3" will the bends clear in my tahoe with out seriously moding it?
