ECSB 2WD 80E guys
Old Mar 12, 2014 | 07:55 AM
greasemykey's Avatar
Default ECSB 2WD 80E guys
slip yoke showed up today and all of the stickies and threads i found are 4WD trucks or rcsb trucks.
who has a ECSB 2WD with an 80E that can tell me how much to cut off my slip yoke?
Old Mar 12, 2014 | 08:08 AM
Chevy_King1500's Avatar
5/8'' is what everyone says. i haven't done my 80e swap yet so i can't confirm this
Old Mar 12, 2014 | 08:31 AM
dirt track racer 81's Avatar
Somewhere around that you'll just have to test fit it
Old Mar 12, 2014 | 11:08 AM
Ferocity02's Avatar
Depends on how long your slip yoke is that you got, what kind of output shaft is in the trans, and it just varies from truck to truck I think. I would recommend waiting to cut it until the trans is in the truck and you can test fit it.
Old Mar 12, 2014 | 11:10 AM
sprayedenali's Avatar
i didnt cut mine...? it cam out of an old TH400 though
Old Mar 12, 2014 | 11:53 AM
GMCtrk's Avatar
No cutting required on mine. I used a neapco yoke and i confirmed an ideal amount of spline engagement. Knowing which output shaft you have, as mentioned is critical.
Old Mar 12, 2014 | 12:53 PM
I took mine from a 400 as well
Old Mar 12, 2014 | 01:18 PM
Gadgetized's Avatar
Slide it in the tranny. If it will slide in far enough to knock the soft plug out of the back there is no need to cut it at all. You should really balance the driveshaft with the yoke installed.
Old Mar 12, 2014 | 08:37 PM
it slides on and you hear it click when it bottoms out. there is about 1.5" of it sticking out past the tail shaft
Old Mar 12, 2014 | 08:55 PM
Gadgetized's Avatar
Dont forget that the 80e rear seal has a dust lip that sticks back from the tailshaft.
