Dropping My Truck????
Old Sep 28, 2008 | 10:56 PM
05blacksilverado's Avatar
Registered User
Default Dropping My Truck????
I got a 05 singlecab silverado with 20" ss wheels.....Im thinking a 2/4 drop.....any suggestions on brands or what to use to drop IT?
Old Sep 29, 2008 | 12:20 AM
02slow4.8's Avatar
i was thinking of the same drop on my truck... single cab and same wheels. after researching it, i was going to do drop spindles in the front and hangers/shackles in the back..... along with new shocks of course. i kept reading that drop spindles would be superior to lower shocks or drop lca's because it will hardly mess with your front end geometry, if any. i personally was going to go with a DJM kit but i've heard good and bad things about companies.
Old Sep 29, 2008 | 01:25 AM
95 bright teal's Avatar
+1 on spindles hangers and shackles, mcgauhys and belltech are similar and both have good reviews
Old Sep 29, 2008 | 01:31 AM
Diablo666's Avatar
I like my drop kit (in sig). I lost some turning radius with spindless on front, is pretty hard to make U turns on a two lane street, that's the downside of my kit. I've red that springs in the front won't affect your turning radius but you will end up with a stiffer ride and bumpsteer.
Old Sep 29, 2008 | 03:33 PM
barley's Avatar
I had 2" drop LCAs and shackles and hangers on my last truck with edelbrock IAS shocks all the way around. It was great now i got 2" drop springs and shackles and hangers on my new truck and **** shocks and the ride sucks. If you want good ride quality spend some money it's well worth it. Remember most spindles take a 17" wheel to clear em so if you have a flat on the front your spare will not fit
Old Sep 29, 2008 | 03:53 PM
chevrolet all the way's Avatar
it wasnt because of scrubbing you lost turning radius is it?
Old Sep 29, 2008 | 06:31 PM
no there is clearance issues with the spindles you just need to grind them down and you get the steering back.
my truck is a spring drop up front, if you want it to corner like its on rails its not a bad way to go. my truck takes turns way faster than my camaro ever did!
Old Sep 29, 2008 | 06:55 PM
Dezert1500's Avatar
they do have spindles for 16" rims but your turning radius will nearly double(slight exageration but you wont like it)
i dont think so I believe the spindle is narrower to fit and that moves the steering closer to the hub making less turning
I have never heard of the fix, i have read many threads on the issue and most people took them off, sorry
Looks like you took my advice and are passing it on to others. Good to hear the spindle rumor needed to die.
Old Sep 29, 2008 | 07:04 PM
Well now that i know it can be fixed ill tell people, before you told me i was told it couldnt be fixed
Old Oct 4, 2008 | 10:49 PM
johnnyh8's Avatar
so springs would be the way to go if i didnt want to grind anything down for 17's ( or spend more money i dont have). are springs a lot stiffer or just slightly over stock? although if it handles like you mentioned, i wouldnt really care if it was a little rougher ride.
