Dropping 07 OBS short crew 4X
Old Nov 26, 2008 | 05:24 PM
Default Dropping 07 OBS short crew 4X
I recently picked up an o7 old body style short crew. I pulled the rear blocks out of the back to drop the rear and it helped a bunch. I'm wanting to drop it a bit more Is it just a matter of spindles up front and drop hangers for the rear. After looking at it with just the blocks removed the rear bumpstops are super close. Do I need to get a set for a 2wd or just wack the plate off of the frame and forget about it. My other question revolves around pinion angle will I need to get a set of degree shims for the rear to avoid problems. Or is there a complete turnkey package I can get that does it all. Thanks.
Old Nov 26, 2008 | 09:03 PM
andrew383's Avatar
traveling mod
get with NORCALLSS on here he's the lowering master lol
Old Nov 26, 2008 | 09:13 PM
RandomHero's Avatar
If you want to do it right get 2" mcgaughy's drop spindles for the front and some shackles for the rear.
That will give you a 2/4 from the original stance. 95% of the people don't have to worry about pinion shims with this.
Old Nov 26, 2008 | 10:37 PM
KevinF56's Avatar
how low are you looking to go?
you could just put on lowering shackles and decrank your torsion bars. that will give you ~2 more inches all around.
my truck for example has this done (also minus the lift blocks):
Old Nov 26, 2008 | 10:50 PM
budhayes3's Avatar
PT's Slowest Truck
My setup consists of Belltech lowering keys, lift blocks removed, 2" shackles, and spring clamps...the poor man's drop. If I had the cash and didn't put 16" wheels on in the winter, I probably would have done spindles up front. Maybe some day I'll add spindles and hangers and go even lower
Old Nov 26, 2008 | 10:55 PM
budhayes3's Avatar
PT's Slowest Truck
Your truck is super clean man
Old Dec 1, 2008 | 04:40 PM
Appreciate Ordered a kit from mcaugheys today. Spindles and hangers
Old Jan 1, 2009 | 01:47 PM
I'm going to start installing everything this weekend. How will the 265/7017 tires clear with the mccaugheys 2-4 drop.
Old Jan 1, 2009 | 08:02 PM
BigCountryx's Avatar
spindles and shackles i hope. Just hangers without sahckles will have your pinion angle screwed from what I gather.
Old Jan 4, 2009 | 04:33 PM
I did the front spindles, ditched the blocks in the rear and did drop shackles.
