Driveshaft Loop
Old Sep 12, 2011 | 10:16 PM
SRTKLLR's Avatar
Default Driveshaft Loop
I recently had the bolts holding the driveshaft/u-bolt break and was wondering if anyone makes a loop specifically for our trucks?
I searched and read a couple of old threads but maybe someone finally came up with one instead of everyone fabbing one up or trying to use a universal one.
Plus, I was told I needed one last month because I use DR's a the track.
Old Sep 13, 2011 | 02:10 AM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Every loop I've ever seen for the trucks was a slightly modified universal kit, or completely home-brewed.
I think that if one of our sponsors was to start building them, they would sell pretty good. (hint hint)
Old Sep 13, 2011 | 02:43 AM
Mangled03gmc's Avatar
Baltimore Whore
What AK said....
I will start taking orders
Old Sep 13, 2011 | 10:09 AM
SRTKLLR's Avatar
What AK said....
Well put me on that list. I can't believe no one is making them yet.
Old Sep 13, 2011 | 11:44 AM
fastrt's Avatar
11 Second Truck Club
I will take 2....
Old Sep 13, 2011 | 12:24 PM
Swerve7rpm2000's Avatar
If i had someone with a truck like yalls around here i would tig some stuff up for yall lol
Old Sep 13, 2011 | 02:36 PM
SRTKLLR's Avatar
OK, I crawled under the truck a little while ago and it seems the truck has a cross member from the drivers side frame to the passenger side. It should be easy to mount a loop to it. That is why my DS did not hit the ground when I sheared the bolts the other day. It was being held up about 2 inches off the ground by the cross member.
I think I am going to get one put in the rear also because if not the DS can destroy the fuel tank and/or muffler.
Old Sep 13, 2011 | 02:43 PM
Baltimore Whore
Here is the loop I made up, so they would be similar to this.. IIRC there is 2 holes on each side of the frame rails that this is bolted to( been a little while since I been under the truck)
I also have one in the rear, but it is welded to the frame of the truck.. The fuel tank was a issue for me also...
let me know if your serious..
Old Sep 13, 2011 | 07:53 PM
terravast4's Avatar
How much for a set?
Old Sep 13, 2011 | 08:02 PM
Baltimore Whore
The rear would have to be welded on not bolted on atleast the way i ahve mine.. The fron set I will ponder up a price..
