Driveshaft Loop
I recently had the bolts holding the driveshaft/u-bolt break and was wondering if anyone makes a loop specifically for our trucks?
I searched and read a couple of old threads but maybe someone finally came up with one instead of everyone fabbing one up or trying to use a universal one. Plus, I was told I needed one last month because I use DR's a the track. |
Every loop I've ever seen for the trucks was a slightly modified universal kit, or completely home-brewed.
I think that if one of our sponsors was to start building them, they would sell pretty good. (hint hint) :) |
What AK said....
I will start taking orders :nod: |
(Post 4771567)
What AK said....
I will take 2....
If i had someone with a truck like yalls around here i would tig some stuff up for yall lol
OK, I crawled under the truck a little while ago and it seems the truck has a cross member from the drivers side frame to the passenger side. It should be easy to mount a loop to it. That is why my DS did not hit the ground when I sheared the bolts the other day. It was being held up about 2 inches off the ground by the cross member.
I think I am going to get one put in the rear also because if not the DS can destroy the fuel tank and/or muffler. |
3 Attachment(s)
Here is the loop I made up, so they would be similar to this.. IIRC there is 2 holes on each side of the frame rails that this is bolted to( been a little while since I been under the truck)
Attachment 144358 Attachment 144359 Attachment 144360 http://i6.photobucket.com/albums/y21...075/005-13.jpg I also have one in the rear, but it is welded to the frame of the truck.. The fuel tank was a issue for me also... let me know if your serious.. |
How much for a set?
The rear would have to be welded on not bolted on atleast the way i ahve mine.. The fron set I will ponder up a price..
