Drag Racing and 4/6 Drop
Old May 12, 2007 | 03:43 AM
Dirty 30's Avatar
LS1Tech Whore
Question Drag Racing and 4/6 Drop
Got a buddy with a 99-02 RCSB Sierra stepside wanting to drop his truck 4/6. He wants the truck for drag racing and doesnt really care if its all draged out. He wants to know what suspension setup is best for drag racing and should he go with less of a drop for best results?
Right now the suspension is all stock. Motor is a built 5.3L with cam for nitrous, built 4l60e, built rear end. Hes going to probably get a 408 for nitrous and another built tranny n rearend.
thanks
-Jesse
Old May 12, 2007 | 04:00 AM
RandomHero's Avatar
well you want something that will be transfer like stock. Obviously a 4link with coilovers or similar setup would be best, but we all can't blow 2-3 grand on a rear setup.
You want something that won't change your geometry or suspension travel. Running control arms and a flip kit won't change anything with your stock setup. All it does is angle the control arms to achieve a 4" drop, and a flip kit does just that, it flips the leaf springs under the axle.
Old May 12, 2007 | 08:01 AM
bgray's Avatar
TOTM: June 2007
i was jsut at the track...4/6 with a flip kit and notch...seemed to work pretty good...but the 4 link, panhard bar, and coilovers is the best s3etup around for draggin
Old May 12, 2007 | 08:25 AM
nightrunner's Avatar
Mr. Obvious
i dont think the 4/6 will be hurting him, but if he wants to go wiht less drop, id say a spindle/shackle/hangar-2/4 drop with some caltracs and qa1 shocks would work great, but thats just specualtion
Old May 12, 2007 | 08:32 AM
02BlueStepside's Avatar
You can do caltracs and qa1s with a 4/6 too
Old May 12, 2007 | 09:28 AM
bluecajun5.3's Avatar
11 Second Truck Club
i wonder what's the best 60' on here that anyone has cut with a 4/6 drop?
Old May 12, 2007 | 09:39 AM
shakesvho's Avatar
when you were running your 4" leaf packs how did they treat you
Old May 12, 2007 | 10:08 AM
Cuerva's Avatar
I hava a 4/6 on mine. Rear: 6" flip kit, helper springs (basically clamped springs), Air shocks. Front: spindles/coils.
The best I've got has been a 1.74 60' on motor with 26's and 27's and 1.65 on spray with Hoosiers 28's. Going with Caltracs and have to check on shocks. This should help me get out of the hole and not break the tires loose everytime the truck unloads.
Old May 12, 2007 | 10:48 AM
Derek @ EDO's Avatar
FormerVendor
the best ive cut on my 28" hoosiers was a 1.69 all motor!
Old May 12, 2007 | 10:55 AM
Raffman's Avatar
I had a 4/6 drop on mine and the right side rear lower shock mount would either loosen up or break constantly. when it did, it was bad wheel hop. Ditched that for the airride but haven't been back to the track yet for 60ft.
