does 480le use alot more hp over a 4l60e
Old Aug 1, 2006 | 10:54 PM
Tahoe6.0's Avatar
Default does 480le use alot more hp over a 4l60e
I'm doing a LQ4 swap in a 02 tahoe and was going to use the 4l60e trans with a nelson tune, but would it be worth the 480le swap also? The 1st gear ratios on the 60le are better than the 80le. I think the trans will hold up? I tow a 30' 7000lb trailer once in a while. Is there info on the swap somwhere that I can get with part numbers. Can I still use the 02 pcm with a 480le transmission? Need some help please.
Old Aug 2, 2006 | 12:40 AM
not sure if you can use the same PCM but yes the 80 takes a biut more power to get moving but i dont think your 60 will hold up long. unless you dont really decide to put anything more into the engine. IMO get the 80 or a built 65. it'll be worth it
Old Aug 2, 2006 | 01:45 AM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
The 80e swap isnt necessary for what you are doing unless you are going to beef up the 6L alot. Get a built 65e like FLT's Level 5 and be done with it. Its not worth the extra cost for the 80e swap at your power levels and towing weight.
Old Aug 2, 2006 | 07:14 AM
Lord Aries's Avatar
My 80e cost me 12HP more then the 60e when we compared on the dyno but, i wouldn't trade the comfy feeling of have a 1,000+HP handling transmission for any built 60e or 65e....
Old Aug 2, 2006 | 09:04 AM
thunder550's Avatar
High on diesel fumes
Your PCM can have the transmission segment rewritten to control either the 60 or 80.
Wolftrk99
Dec 3, 2015 08:12 PM
Wolftrk99
Oct 2, 2015 08:17 AM
jamesm32
Sep 24, 2015 11:49 AM
RONIN LSX
Sep 19, 2015 05:33 PM
