does 480le use alot more hp over a 4l60e
I'm doing a LQ4 swap in a 02 tahoe and was going to use the 4l60e trans with a nelson tune, but would it be worth the 480le swap also? The 1st gear ratios on the 60le are better than the 80le. I think the trans will hold up? I tow a 30' 7000lb trailer once in a while. Is there info on the swap somwhere that I can get with part numbers. Can I still use the 02 pcm with a 480le transmission? Need some help please.
not sure if you can use the same PCM but yes the 80 takes a biut more power to get moving but i dont think your 60 will hold up long. unless you dont really decide to put anything more into the engine. IMO get the 80 or a built 65. it'll be worth it
The 80e swap isnt necessary for what you are doing unless you are going to beef up the 6L alot. Get a built 65e like FLT's Level 5 and be done with it. Its not worth the extra cost for the 80e swap at your power levels and towing weight.
