differential bolt heads stripped
Old Apr 2, 2009 | 07:06 PM
KeukaZ71's Avatar
Default differential bolt heads stripped
was going to change my diff fluid the other day and the head of the one of the bolts stripped. any suggestions?
Old Apr 2, 2009 | 07:17 PM
james07shortbed's Avatar
die grind a notch in it so you can get a flat blade screwdriver in it then hit it
with a dead blow hammer and hit and turn tell it bust loose.
Old Apr 2, 2009 | 07:29 PM
KeukaZ71's Avatar
should i try a vise grip first?
Old Apr 2, 2009 | 07:32 PM
BlownHD's Avatar
Yes you can do that. If you have a welder, you can also weld a nut to the end of the bolt and then get a wrench on the nut.
Old Apr 2, 2009 | 07:46 PM
Mangled03gmc's Avatar
Baltimore Whore
Grind the head off the bolt, then use vise grips to get it out...after the cover is off. Or like said weld a nut to it..
Old Apr 2, 2009 | 08:11 PM
1_fastsilverado's Avatar
If you just want to change the fluid, I'd take out the drain plug under the differential and then refill it through the fill/check plug (obviously haha). I didn't know these had drain plugs on the bottom till tonight when I put my TA girdle on and saw it under there.
Old Apr 2, 2009 | 08:27 PM
willymac's Avatar
if you are one of the lucky few that have a drain plug on the rearend.
Old Apr 2, 2009 | 09:50 PM
nonnieselman's Avatar
Id try the notching it and use a flat head screwdriver... if that doesnt work, weld a bolt or nut to it and try that.. if thats not successful then just grind the head off and use visegrips..
Old Apr 2, 2009 | 11:45 PM
howard quick's Avatar
If you have a welder....save alot of mucking around and just weld a large nut to it.
slowlsx
Aug 10, 2015 05:33 PM
vipergtrdj
Aug 6, 2015 10:19 PM
signguy62
Jul 27, 2015 03:42 PM
fat tony157
Jul 16, 2015 12:35 PM
