Corvette Servo Install W ALOT of pics
Old Nov 18, 2012 | 11:32 PM
  #81
bluebird71's Avatar
Installed the servo this weekend. A lot more tranny fluid came out than I expected. Almost a full quart. I would definitely recommend picking up an extra quart before doing this job. Other than that, it worked out great. The transmission shifts firm and proper. Its not tire chirping firm, but it feels like it should have in the first place.
Old Nov 22, 2012 | 05:08 PM
  #82
RedRover's Avatar
Originally Posted by Whitebread22
I proudly mentioned this to one of the techs here at my shop and he said the TCM would eventually relearn and start to shift like it did orginally. Any truth to that?
That's like saying if you put a cam in, the computer would relarn itself and run like stock, i would never let that tech touch my ****!
Old Nov 22, 2012 | 09:09 PM
  #83
Onetogofast's Avatar
What is everyones input on doing the servo and a shift kit as well? Over kill? I have put shift kits in many transmissions and never knew about doing the servo.
Old Nov 26, 2012 | 03:05 PM
  #84
So.cal Wrk Sled's Avatar
Rhino Thx for this info!! did mine last nite!! The hardest thing was jacking up trk.This has to be the cheapest mod with best outcome by far.! "BEST 24bucks EVER spent!"
Old Dec 13, 2012 | 11:35 AM
  #85
Just installed mine, easy 45 minute job. 1-2 feels a little diff but not major. The one thing I did notice is that my 2-3 is not sloppy and almost pointless anymore, its not very firm but hit right to 3rd without delay now. Add a shift kit later and all will be good!!! Thanks for the write up
Old Dec 13, 2012 | 05:03 PM
  #86
Twentyhurtz's Avatar
Thank you for making this thread, I will be using it as an aid soon!
Old Dec 18, 2012 | 05:42 PM
  #87
BCraven1018's Avatar
Thanks for the pics Rhino. The pics were a big help.
Old Jan 7, 2013 | 08:19 AM
  #88
Choda's Avatar
Used this thread and installed my vette servo last night. took 40 min start to finish. I also took a bunch of pics incase anyone needs them. Shifts are a lot more firmer for 1-2 and 2-3. Everything worked great!
Old Feb 1, 2013 | 11:47 AM
  #89
elguapo9's Avatar
Registered User
Installed the servo yesterday, had to finish up today. Big help with this thread. Unfortunately, I got distracted at the end, buttoned everything up and then noticed the 4th apply piston sitting on my workbench. So I ran to the local tranny shop for a new blue o-ring and popped that sucker in this morning. Runs and shifts great.
One thing worth mentioning, on my 02 2wd, I had to remove 3 of the 4 tranny crossmember bolts so I could lower the passenger side of the tranny to remove the servo. From google it sounds like this is a feature of the '02's only? Anyway, with the trans dropped on one side like that it makes it real easy for the servo return spring to fall off of the snout, so you have to be careful with that.
Great write-up!
Old Feb 1, 2013 | 12:42 PM
  #90
1FSTGMC's Avatar
formerly 2low4nd (11-08-2011)
Great thread.
