Corvette Servo Install W ALOT of pics
Old Jun 13, 2016 | 08:17 PM
  #121
Tig's Avatar
Tig
It looks like you got it wolf, that bronze washer seems to have come with the kit. I think a couple of the springs did as well.
Its weird how I couldn't get the cover back on with the washer in place. I'm wondering if it was not seated correctly.
Thanks man
Old Jun 13, 2016 | 08:28 PM
  #122
Wolftrk99's Avatar
Those washers are design for the standard servo not the vette servo, vette servos negate any of servo mods in the shift kits, typically.... Only kit ive seen that didnt matter was the sonnax performance pack with the single servo spring....
Old Jun 13, 2016 | 09:25 PM
  #123
Tig's Avatar
Tig
Ahhh, thanks again man, I appreciate the help
Old Jun 13, 2016 | 09:27 PM
  #124
Wolftrk99's Avatar
No problem!!!
Old Jun 25, 2016 | 07:51 AM
  #125
yetavon's Avatar
Registered User
Nice easy to follow write up. Mine was a PITA, no room to remove it in one piece.
Thanks
Old Oct 1, 2016 | 10:01 AM
  #126
ILuvJDM's Avatar
I cannot get the pin to slide out of the housing. I've removed everything down to the last step, even the circlip and the pin just bangs back and forth and does not slide out of the housing. Any ideas?
Old Oct 1, 2016 | 02:40 PM
  #127
ILuvJDM's Avatar
Got it figured out, just had to file down a small burr that made a shoulder of sorts on the pin. After that it slid out just fine
Old Oct 1, 2016 | 03:11 PM
  #128
Wolftrk99's Avatar
Sounds like you need a new pin...
Old Nov 21, 2016 | 08:10 PM
  #129
bebates's Avatar
Registered User
Default What should I get?
I am trying to decide exactly what I want to do in regards to transmission servo upgrades.
I tow a boat mainly on the freeway. That is the main reason for the upgrade.
Would you recommend-
1. Corvette servo upgrade
2. Corvette servo upgrade with long pin
3. Corvette servo upgrade with long pin and a 4th apply piston
4. Corvette servo and 4th apply piston
Thank you in advance for the input.
Old Nov 22, 2016 | 10:56 PM
  #130
Wolftrk99's Avatar
Vette servo and sonnax performance pack with hd 2-3 valve, fix all the shifts not just 2 and 4, and apply overruns when in manual 1,2,3...
