Corvette servo install, help
Old Jun 26, 2005 | 03:11 PM
Searching4Sierra's Avatar
Unhappy Corvette servo install, help
i have everything back together, but i cant get the final snap ring for the cover to go back on, ive tried for an hour. please help, any tools or techniques, it seems impossible.
Old Jun 26, 2005 | 03:58 PM
Coban's Avatar
I had the exact problem. I found that when I put in one side and then started to spin the snap ring, it went right in. Unfortunately I think it was partly just luck.
Old Jun 26, 2005 | 04:00 PM
w41quad4's Avatar
Make sure you have the whole thing put together properly so that the cover will push in far enough to get the snap ring in place. I used a makeshift press *a vise-clamp reversed to spread, put it against the cover & against the exhaust* anything will work you just have to get the cover in far enough to get the snap ring seated. The O-ring is real tight so getting it in there the first time can be a pain. Once its in it will pretty much stay seated so you can push the ring in by hand.
Old Jun 26, 2005 | 05:27 PM
i went out and tried everything, still no luck. even with two people, please help
Old Jun 26, 2005 | 05:35 PM
SSlow 4.8's Avatar
thats a pita i know... i found a piece of an old table that sat flat on the ground, it had a hole in the middle so i could place it down in the hole and have someone push with a screw driver on top to condense the spring while i put the snap ring on... lol it WASNT easy. Took about 3 tries with pushing the spring down and clamping the ring in place.. see if you can find something that you can do like that with a hole in it.. preferably lower than waist height so whoever is pusing the screw driver in can put all their weight into it.
Old Jun 26, 2005 | 06:06 PM
gonzo 6.2's Avatar
Is the 4th servo in backwards?Can you tell that the cover is going in far enough?Is the problem the handling the snap ring? Did you do transgo spacers?or a longer pin?
Old Jun 26, 2005 | 06:09 PM
Rhino79's Avatar
9 Second Club
I used a prybar on the center of the cover, put a little dab of grease on the o-ring also. That should help the o-ring go in easier. Also if that doesn't do it make sure the spring on the inside, the one that goes in the case first, is installed right and is not sideways.
Old Jun 26, 2005 | 06:23 PM
everything is in correctly. tomorrow im gonna borrow the gm tool from work. the tool bolts into the tranny pan and it should make the job a lot easier, thanks for all your help.
Old Jun 27, 2005 | 10:48 PM
ok i wasnt pushing the servo cover in far enough, i saw a tranny at work and noticed that the snap ring was farther back then were i was trying to put it in. the gm tool works great if anyone wants more info on that, it went in in one try. seems like my 1-2 shift is faster now. thanks for the help
X_Racing1
21
Mar 30, 2016 02:37 PM
pittman
Jan 19, 2016 07:06 AM
spiritfish
Aug 23, 2015 09:58 PM
lycominghunter
Aug 15, 2015 12:26 PM
Ferocity02
Aug 7, 2015 08:50 PM
