Converting AWD t-case to RWD only???
Old Oct 16, 2008 | 09:43 PM
Default Converting AWD t-case to RWD only???
I Know Someone Has Done This On Here Before And Need To Know How To Do It. I Can Pick Up A T-case Cheap And Mod It To Make It Work If It Is Possible. This Is For Tuning Reasons, My Truck Does Not Fit On Any Awd Dynos, Too Long Of A Wheel Base.
Old Oct 16, 2008 | 09:46 PM
stock48's Avatar
9 Second Truck Club
Pull out the front drive line for the dyno.
Old Oct 16, 2008 | 09:48 PM
viciousknid's Avatar
Where's the Beef?
Originally Posted by stock48
Pull the front drive line for the dyno.
+1.
just takes a few minutes.
Old Oct 16, 2008 | 09:49 PM
HEARD OF PEOPLE DOING THIS BUT WITH THAT CLUTCH HOLD UP UNDER SOME SERIOUS POWER??
Old Oct 17, 2008 | 01:21 AM
1Bear's Avatar
04Denali (Mark) had one modified to dyno his '04 Denali. I believe Senergy done or had it done for him. I believe there is mention of it here: https://www.performancetrucks.net/fo...light=04denali
Old Oct 18, 2008 | 12:25 AM
stock48's Avatar
9 Second Truck Club
Another option might be to swap in a part time non electric 4x4 Tcase out of a truck, lock it in 2wd, and leave the front driveline out. You might need the rear driveline out of a tahoe, swap shouldn't take more than an hour or two.
Old Oct 19, 2008 | 12:47 PM
I THINK I AM JUST GOING TO TRY TO REMOVE THE FRONT SHAFT AND TRY IT, IM LOOKING FOR A T-CASE FOR BACK UP, IF I BREAK THIS ONE, THEN ILL JUST MOD IT TO MAKE IT 2WD
Old Oct 25, 2008 | 11:27 AM
EVILGMC's Avatar
If you break the t-case, might be worth ditching the 4l65 and putting in a 2wd 4l80. Im sure there are some buyers for your leftovers...
-pb-
Old Oct 25, 2008 | 01:36 PM
1989k1500's Avatar
Like mentioned if your that worried buy a floor shift t case and put it in, just select 2wd when your under the truck. AFAIK they are the same length as an awd case.
Old Oct 25, 2008 | 03:21 PM
do they use the same drive shafts???
front and rear??
blownss27
Aug 14, 2020 08:27 AM
chvy=power
Sep 8, 2015 11:06 AM
Cowboy Tom
Sep 5, 2015 04:29 PM
Alvin@PCMofNC
Sep 3, 2015 06:38 AM
Three6GMC
Aug 28, 2015 07:56 AM
