Converting Awd to Rwd
Old May 22, 2012 | 08:27 AM
ashoooon's Avatar
Default Converting Awd to Rwd
I have a denali '08 Awd and I want to but it on dyno . So I want to converting it from awd to rwd because the workshop that I perform my truck on it just has rwd dyno.
Old May 22, 2012 | 09:53 AM
Whitecrewcab's Avatar
Just to dyno it, I would yank the front driveshaft out of it. Does the yoke stay in the transfer case or is it part of the driveshaft?
Old Jun 5, 2012 | 09:13 AM
ashoooon's Avatar
I try it but its doesn't work
Old Jun 5, 2012 | 12:28 PM
Silverad0 SS's Avatar
No!! Your best bet is to find an awd dyno, you can dyno it in 2wd but it is very risky, I can't remember the steps, but I read the steps on silveradoss.com
Old Jun 5, 2012 | 07:10 PM
1Bear's Avatar
In the OPs case, pulling the front driveshaft is not an option. Unlike the earlier model GM trucks and SUVs equipped with the NVG-149 that had the viscous coupler, the newer style cases are an open differential type the works in conjunction with the ABS to transfer power. If one were to pull either shaft, the power would be automatically directed towards the end without load.
Old Jun 5, 2012 | 07:36 PM
La SS's Avatar
Pull the front cv shafts
Old Jun 5, 2012 | 08:02 PM
Onetogofast's Avatar
Can't do that, the wheel bearings wont stay together without the splines and big nut holding it together.
Old Jun 5, 2012 | 08:05 PM
rj2's Avatar
rj2
Whats done to the truck youre wanting to dyno? Just curious.
Old Jun 6, 2012 | 01:00 PM
La SS's Avatar
Let me rephrase that. Cut the cv shaft after it connects to the hub, buy another set before you do this lol
Old Sep 22, 2012 | 03:47 PM
MoeDenali's Avatar
you need to pull some plugs.
