Converter size??
Old Mar 28, 2007 | 07:32 AM
SSSBLKOUT's Avatar
Default Converter size??
Whats the difference between a 10.5" and a 9.5" converter when they are both set at the same stall speed? Also, what is the benefit of a MULTI DISC setup in the lockup converters?
Im gonna be getting a new tranny/TC soon, and I am trying to figure out what everthing does. Thanks
Old Mar 28, 2007 | 07:38 AM
My experience has been that the smaller the converter the "looser" it is.
Old Mar 28, 2007 | 08:19 AM
SSSBLKOUT's Avatar
Define LOOSE? I know that theres a "feel" to the term. does that mean not predictable?
Old Mar 29, 2007 | 08:04 AM
No, its kind of hard to explain unless you are familiar with converters. Say you have 2 3000rpm stall converters in the same vehicle with the same mods. (All things equal besides the 2 converters) Although they both may flash to 3000 rpm the smaller one may take more throttle to get it moving (street driving) than the larger dia. converter. Again I am no expert on converters but I have had my fair share of experience with them.
Something else to keep in mind, with the larger diameter converter although it is advertised as 3000 rpm it may not actually flash that high where as the smaller diameter should.
Old Mar 30, 2007 | 05:52 AM
SSSBLKOUT's Avatar
Ok, so, the sort version is that a 3000 stall 10.5" tc will consistantly respond like a 2800, and a 3000 stall 9.5" will act like a 3000 stall MOST of the time, and sometimes like a 3200?
Old Mar 30, 2007 | 12:58 PM
ZZebes's Avatar
basically the 9.5" will kill your towing and send your trans temps through the roof. the 10.5 will be easier to drive around town. the multidisc lockup will help keep your highway mileage the same.
Old Mar 30, 2007 | 04:10 PM
Yep to what you both said.
Old Mar 30, 2007 | 04:26 PM
SSSBLKOUT's Avatar
cool thanks
Old Apr 1, 2007 | 04:24 PM
Quik's Avatar
5 year bitches!
i wouldnt put a 9.5" in anything but a RCSB. i had one in mine and temps were warm for sure. and it was loose
TAPyvehc93
Jul 23, 2017 10:54 PM
Stainless Works
13
Nov 5, 2015 03:31 PM
maxspeed05V
Aug 12, 2015 06:29 PM
FlowmasterMufflers
Jul 30, 2015 05:03 PM
jrplz
Jul 9, 2015 12:07 AM
