converter question
Old Jan 11, 2006 | 08:57 PM
12sec.5.3's Avatar
Default converter question
I'm slightly worried about the hub on the back (flex plate) side of the converter. About half of it has a lip around it and the other half is just square. This fits inside the crankshaft for extra stability, I was told. Does this need to be perfectly round or does it not matter. I did look at my stock converter which was taken out about 2 years ago and it looked the same way. Is this something that I should be worried about?
Old Jan 11, 2006 | 11:18 PM
The squarish part is facing the flex plate and the round part is facing the transmission. The reason for the squarish front side is because that is where the lockup disc is located, when engaged the input shaft is rotating at the same speed the engine is. Before the lock up converters, the TC where round on both sides, kinda look like a doughnut with the pump drive on one side and the mounting tabs on the other.
Old Jan 12, 2006 | 05:31 PM
12sec.5.3's Avatar
Not the actual converter, I'm talking about the hub that goes inside of the crankshaft. It's about 1" to 1.5" long.
GXPJAY
Feb 13, 2022 08:15 AM
Jblake
Aug 17, 2015 12:59 PM
USMCvet0311
Aug 1, 2015 07:45 AM
WICK3DxGATA
Jul 21, 2015 06:59 PM
grantpo
Jul 15, 2015 12:21 PM
