compressor ideas?
Old Dec 26, 2009 | 08:35 PM
2001CamaroGuy's Avatar
Default compressor ideas?
I'm trying to decide what to do for a compressor on my air suspension setup. It's 2 bags (2600lb each) in the rear with future plans to install 2 bags on the front (strut-bag in place of the current coilover spring I have).
I don't need anything super "fancy" as I plan to simply "set it and leave it". The pump will just be there to increase pressure in the bags if I add load (want to carry stuff in the bed).
I was thinking I might find an old compressor out of a Cadillac (or equiv) with air suspension. Would that generate good pressure (I'd like to see 90-100psi)? If not, what's a good budget compressor?
Old Dec 26, 2009 | 09:17 PM
Truckshop's Avatar
the ford air-ride compressors are another good choice. they max out at over 200psi. just don't expect them to last if you run it too much.
Old Dec 26, 2009 | 09:19 PM
thanks for the info.
I don't plan to run it much at all. I'm installing air so I can:
1- have a soft ride
2- carry more stuff
so as I said, I will pretty much "set it and leave it" unless I'm loading up something...
what year/model fords have the air-ride compressors?
Old Dec 26, 2009 | 09:43 PM
Truckshop's Avatar
lots and lots. most lincoln's, expeditions, grand marquis, town cars, navigators. many to choose from
Old Dec 26, 2009 | 09:44 PM
good deal. just making sure it wasn't something specific you were mentioning.
Old Dec 29, 2009 | 12:59 AM
3406a's Avatar
Personally I like Viair. I would go with a 325 which is what I first started out with for $150. I ran it for 5 years with no problems way past the 150psi mark. Now Ive upgraded to triple 460's. They make a great product and have excellent customer service (Lance).
Old Jan 3, 2010 | 08:41 PM
ok, so after look all over I would end up paying $100+ for a used OEM compressor (ford/GM/range rover/etc) so that doesn't look like a good way to go.
I'm now looking at either a Viair 350, 380, or 480. I kind of like the idea of having 200psi but I'm not totally set on that.
As I have stated before, I don't plan to air up/down the system on a regular basis. My idea is to set the pressure in the bags to a soft ride and then only increase pressure if I need to carry more load. I'm looking at using either a 0.5 or 1gal tank. Any input?
The other thing I REALLY REALLY REALLY want is the compressor to be quiet.
Old Jan 12, 2010 | 06:47 PM
ttt....anyone?
Old Jan 18, 2010 | 09:23 PM
3406a's Avatar
Which vehicle are you mounting it on? With that tank size i would stick with the 300 series. I liked my 325 when I first got it, simply because it pumps real fast but lacks the duty cycle. Thats why I've upgraded.
kha4079
Oct 29, 2018 04:38 PM
SlvrSierra4.8
Oct 1, 2015 09:39 PM
Cammed4ever
Sep 30, 2015 03:38 PM
5.3lSilverado
Sep 20, 2015 06:48 PM
mr03silverado
Sep 2, 2015 11:43 PM
