Changing rear diff. fluid
Old Jul 8, 2006 | 07:16 PM
  #21
ZR1 DREAMING's Avatar
Originally Posted by spoon98hatch
yeah I got the cover off, along with the fill hole, and I'm cleaning it up now before I re-install it
thanks for the help
so my next question is, do I fill the diff. until it leaks out the hole? or do I leave it 1/2" from the bottom of the fill hole?
I could have swore I gave you all the info on the first page... don't sweat this out man, it's easy.
Old Jul 8, 2006 | 07:23 PM
  #22
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Owners manual says to fill it to about 1/2" below the hole...
Old Jul 8, 2006 | 07:33 PM
  #23
yeah I still went by what u said.
I just finished about 30mins ago, so thanks a lot to everyone for helpin me out. it really wasn't that hard, but I just like to know exactly what i'm doing before I start to undertake a project.
no leaks so far and everything looks good.
thanks again
-John
Old Jul 9, 2006 | 09:25 AM
  #24
Mort's Avatar
Cool
According to the 2003 Silverado Owner's Manual for the Rear Axle, How to Check Lubricant p.5-55 " The proper level for the 1500 Series is from 5/8 inch to 1 5/8 inch below the bottom of the filler plug hole."
I am not sure if filling it to the bottom of the filler plug hole will cause any problems with expansion and potential leaking or not.
Edit: Well a day late and a $$ short I guess.
Old Jul 9, 2006 | 10:42 AM
  #25
well I read about a guy that had a problem with expansion and leaking out, so he just unscrewed the fill plug, and it basically pushed out all the excess, and he's never had that problem since, but we'll see
Old Jul 9, 2006 | 11:55 AM
  #26
closet red neck's Avatar
Originally Posted by mjhoward
You don't need that additive due to your differential being a mechanical unit with no clutches. Some aftermarket fluids come with friction modifier in there already, just fyi. If you have a clutched posi, like an Eaton, if you don't have the additive in there the clutches will grab when you go around a corner. It chatters bassically, as they are trying to resist slipping rather than slip smoothly in the corner.
Good luck!
So, what kind of fluid do you use with an Eaton locker??? I might have put the wrong stuff in!!!!!
James
Old Jul 9, 2006 | 12:57 PM
  #27
TurboGibbs's Avatar
James
Like I said, most good rear dope's say on them that they are compatible with clutched posi rear ends meaning they already have the friction modifier in it. If not you can purchase the additive at most parts stores. K&W(I think) is the company most parts houses sell. It comes in a tube and is usually near the rear end dope. You can also get it from the dealer. But if yours doesn't chatter when you go around a corner you shouldn't have any problem.
Old Jul 9, 2006 | 01:25 PM
  #28
Thanks for the info!!!!! My wife is @ Wal-mart NOW and she only knows brands.....so what do you recommend!! Synthetic or not?? Hurry....please!!! Don't know if it chatters or not.....radio is always blasting
James
Old Jul 9, 2006 | 01:34 PM
  #29
TurboGibbs's Avatar
I am unsure if synthetics are ok in clutched units. I haven't ran one in years and when I did I used the cheap **** with an additive. Someone posted earlier in the thread about not using synthics or something of that sort. Just make sure the fluid says somewhere on it that it is compatible with limited slip differentials. If it chatters you should be able to feel it as well.
chopperloco
Jul 10, 2016 10:45 PM
gnasty1521
35
Nov 19, 2015 11:42 PM
DarkhorSe_SS
Aug 20, 2015 08:58 AM
walledition
Jul 29, 2015 08:54 PM
MileHighSierra
Jul 22, 2015 11:19 PM
