Changing 2-4 band & reverse input clutch
Old Nov 13, 2010 | 01:23 PM
swift700's Avatar
Default Changing 2-4 band & reverse input clutch
Has anyone here changed the 2-4 band & reverse input clutch in their 4l60e? I'm going to remove the transmission to replace the TC and servos and want to know how hard it is to replace the band and clutch. Are there any special tools involved? I have a little slippage into 2nd at high RPM's.
Old Nov 13, 2010 | 01:37 PM
2BFAST's Avatar
Its not hard. You have to pull the pump, servos, valve body, band anchor in the case, remove the band then the reverse drum. Empty the drum and reinstall in the new and reverse order. Sometimes the hardest part is getting the reverse clutches lined up on the splines on the input drum. Also the pump can be a pain as well getting back in.
Old Nov 13, 2010 | 01:39 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
I don't know how to do it, but I recommend the normal width carbonite band. It has been the only one that has held up for me.
Old Nov 13, 2010 | 03:59 PM
swift700's Avatar
Awesome, guys. I figured it would be fairly simple, being at the front of the tranny. I'll get the carbon band for sure. Thanks for the advice.
ferrellrooster
Mar 6, 2025 03:22 PM
ARC
57
Feb 21, 2022 10:54 AM
07NBSChevy
Aug 9, 2015 12:59 AM
bsn1989
Jul 16, 2015 08:20 AM
MileHighSierra
Jul 12, 2015 12:23 AM
