Can you have TOO much fluid?
Where's the Beef?
I wouldn't say extremely modified. I had to pull the pressure down because the 1/2 was getting annoying and some times would be really hard.
Made it firm but not too aggressive.
Just recently bumped the shift to 6400 1/2 6300 2/3. Shift times are at .1000 apposed to .5-.3
just basic stuff you would do when adding a shift kit.
Runs through the Radiator and the Cooler. I've only ever seen fluid on the over flow tube and it stays cool like it should.
Any chance there is a leak between the rad and the end tank? Do you still run the trans fluid through the rad?
Sounds to me like you either have too much fluid in the trans or pressure is building up in the trans and pushing fluid out. I don't really know enough about the trans to know what might cause it to push fluid out the vent.
The only time fluid usually blows out the overflow is when it overheats. But it sounds like the 3-4's are on there way out, which could be caused by numerous things. Just have to get it apart and look at it. How many miles are on it?
I hate tranny swaps after doin 4 on the ground. At least winter there is warmer than here.
Finish Line Transmissions' limited warranty covers all new products for six (6) months from the date of purchase; and all repair service for thirty (30) days from the original date of purchase. Finish Line Transmissions' sole obligation under this warranty shall be to repair or replace, at its option, the defective parts at no charge to the customer.
Purchased it originally around Feb '08. Refreshed November '08
No, pressure is still set by PCM.
Joshua, have u talked to Vince or anyone @ FLT to ask what's goin on here?
Where's the Beef?
TFT is Transmission Fluid Temp btw.
It's 47 miles 1 way to work. so ~ 100mi per day 5 days a week. I had a NEW Escape and when I wrecked it I had put over 16k miles on it. from July 31'st 06 to Jan 16th? 07.
Ya, u drive a ton of miles.
Sounds like u break stuff on Fri @ 5:01! Right after parts store closes & whoever u need to get ahold of. Sound bout right?
drummer0415
11
Oct 24, 2015 08:16 PM
