Caltracs + Hellwig 7800...
Old Jul 9, 2016 | 03:59 PM
10 Second Club
Default Caltracs + Hellwig 7800...
I am wanting to upgrade my rear suspension more and am curious if these two will work together - or against one another.
My truck is a 100% street truck on 18" street radials. I had some wheel hop with less power. And don't like how sloppy the truck felt with my 18' open car trailer hooked to it with a 3500-4000 lb car loaded on it.
Currently, all I have changed is: 2" lowering shackles and Bilstein 5100s. Both helped, but still not where I want it.
Basically I am trying to accomplish getting rid of the wheel hop from a dead stop or slow roll. And for the back end to not feel so loose with a load or when the road has any kind of curves. I am realistic and realize that it's not a Corvette, but I am sure that it can be better than it currently is.
Thanks in advance.
Old Jul 10, 2016 | 09:01 AM
BigKID's Avatar
Traction bars and a rear sway bar can be used in conjunction and work well together for straight line traction. Together they will make the rear very stiff which may not be ideal for a daily street truck. I recommend trying the rear sway bar first so see how you like it. I believe it will be more beneficial reading your description above. It may even reduce or eliminate the wheel hop as it will provide some resistance to axle rotation.
Old Jul 10, 2016 | 12:55 PM
10 Second Club
Looks like I will be ordering one this week. I will see what it does and go from there. Thank you for the reply and insight.
I have read about it not clearing rear axle girdle covers and large exhaust systems. I hope that it will clear my 3.5" tailpipe.
Old Jul 28, 2016 | 07:03 PM
10 Second Club
Ended up with a belltech rear bar, showed up today. I might get it installed this weekend.
bisqikss
Feb 23, 2017 06:06 PM
MOBBN
Mar 9, 2016 11:59 PM
Nine Ball
Mar 14, 2002 03:11 PM
GREGGO
Feb 27, 2002 05:10 PM
99RedHawk
Jan 16, 2002 08:25 AM
