Caliper Grinding
Old Sep 10, 2012 | 09:24 PM
DTHPROOF's Avatar
Default Caliper Grinding
Well my grudge race is Friday night and I finally ground my calipers to fit my 15" wheels on the rear. Holy crap, what a pain in the ***! It took over 4 hours total. I read a few threads lately that indicated such, but I thought they were exaggerated; WRONG. I probably put on and took off the wheels 30 times on each side, killed a grinder disc, cut my finger down to the bone on my knuckle, and had several slivers of hot aluminum stick in my arms and neck/face. All in all, it was an awesome day.
Old Sep 10, 2012 | 09:33 PM
DTHPROOF's Avatar
I accidentally put this in the wrong sub-forum. Anyone able to move it? Thanks!
Old Sep 10, 2012 | 09:52 PM
03regcab sierra's Avatar
Did the same not to long ago! Never again will i do that. Drum brake swap is much less work
Old Sep 10, 2012 | 09:53 PM
Mangled03gmc's Avatar
Baltimore Whore
Curious to see how much was cut away. Easy way to do it is to take a strait edge from the center of the wheel, measure to the inside of the wheel, then mark it, do the same on the wheel hub to the caliper, mark the cali. Takes alot of time out, trying wheels on and off, LOL
Old Sep 10, 2012 | 10:26 PM
1FastBrick's Avatar
Custm2500's Rude Friend
It's in the drive train section now.
Old Sep 11, 2012 | 06:47 AM
DTHPROOF's Avatar
Thanks brick! I'm going to say they were easily shave 1/8" all the way around the caliper. After I finished grinding, I threw a couple of quick coats of graphite-colored paint on them to match my Torq Thrusts and you can't tell they were cut so much unless you REALLY look. I started using anti-seize on the wheel and spinning it so it would mark the contact points to know where to grind more. That made it better, but still a PITA.
thompson
Dec 27, 2017 06:48 AM
hodge9386
Oct 25, 2015 01:26 PM
twake_410
Sep 25, 2015 10:09 PM
kmcn47
Sep 17, 2015 01:12 AM
silver-mod-o
Sep 12, 2015 01:39 PM
