C-notch- frame sag???
Old Aug 10, 2005 | 09:45 PM
LVSTOGOFST2002's Avatar
how about a plasma cutter?
Old Aug 10, 2005 | 09:48 PM
That is what was used on mine.
Old Aug 11, 2005 | 01:11 AM
8MC's Avatar
8MC
From what I understand, the frames on the NBS trucks can bend like butter when a cutting torch/plasma cutter is used. It has something to do with the forming process. I guess more than a couple shops found this out the hard way. You just have to go slow and brace everything. A sawzall or cutting wheel is probably better for a driveway DIY. My 2 cents
Old Aug 11, 2005 | 06:24 AM
454ss's Avatar
The frame must be supported in front and behind the notch before cutting, also do not tighten the bolts untill the truck is on the floor.
Old Aug 11, 2005 | 09:23 AM
BigPurp's Avatar
This goes for anytime your going to be cutting ANY part of the frame/body. Always brace and support everything MORE than you think it needs. Overkill and peace of mind is MUCH better than trying to figure out how far the rear end drooped when you hacked out a big section.
For the love of god, remove the leaf springs from the shackles (yip even seen shops leave them attached), pull the spare tire, and get anything heavy out of the bed if your going to leave it on.
My personaly feeling is if you have to ask, in this situation do not use a plasma torch, especially that close to the fuel tank. Experienced metal workers can get away with it, but will be much safer using a cutoff wheel and/or sawzall.
Old Aug 13, 2005 | 10:39 PM
slammed1500's Avatar
is it a weld or bolt in
Old Aug 13, 2005 | 10:53 PM
If you choose to use a sawzall be preapred to go through some blades before you get done with both sides.
Dave
flatblack83
Jan 3, 2026 07:10 PM
GMCtrk
Oct 5, 2015 11:18 AM
Cha_Feel_
Sep 23, 2015 09:06 PM
tboy22
Sep 13, 2015 09:10 PM
