burnout
Old Feb 4, 2009 | 03:33 PM
way2much_01's Avatar
Default burnout
I cant get my truck to burnout for nothing I know with all the stuff in my sig i should have no problem. is there something in the tune i can change?I have the traction control disabled
Old Feb 4, 2009 | 04:17 PM
Breeze's Avatar
11 Second Truck Club
Do you have any or all of the torque management removed in youre tune?
Old Feb 4, 2009 | 05:49 PM
jaegmc99's Avatar
dang, thats alot of mods too. Well i guess if you can't burn out it should be some sort of advantage over wheel spinning rcsb trucks. Have you ran your truck against any modded Reg Cab Chevy/GMCs?
Old Feb 4, 2009 | 05:51 PM
95 bright teal's Avatar
You can atleast spin them right? just not roast them. or are you dead hooking all the time?
Old Feb 4, 2009 | 05:59 PM
all tm management removed I cant do anything i got a stall 2
Old Feb 4, 2009 | 06:24 PM
oldred95's Avatar
What rpm is the converter rated to stall at? Seems strange it wouldn't at least make a squeak from the tires. My bone stock 99 will at least do that much. Maybe your torque is just too far up the power band to make the tires spin. Any air fuel ratio readings when you are trying to burn out? Maybe its going lean, maybe its going way too rich in Power Enrichment.
Old Feb 4, 2009 | 06:35 PM
With your cam you should still have plenty of low end grunt, and the stall/gears should make it easy for you.
Do you still have your stock rims/tires you could put on. you weigh more, and have heavier wheels which doesnt help with burnouts
Old Feb 4, 2009 | 07:19 PM
fastgmc53's Avatar
14 Second Truck Club
yeah all those mods should get real nasty...
heres mine as modded now..... needs stall and headers
http://s427.photobucket.com/albums/p...t=P1020078.flv
Old Feb 4, 2009 | 07:32 PM
006rcsb's Avatar
is your avalanche awd? lol
Old Feb 4, 2009 | 07:38 PM
fastgmc53's Avatar
