built 65E slipping after 6months?
Old Feb 28, 2006 | 02:24 PM
OrlandoFL4.8's Avatar
Unhappy built 65E slipping after 6months?
I had a built 65e put in about 6 months ago complete with the following
"high temp raybestos 9 clutch pack (replaces factory 5 clutches),all new steels, bands bushings and rings. A 500 boost valve, 4140 hardened pump rings, a 29 element sprag, Over sized heat treated Sonnax sun shell, hardened input shaft N drum, high temp pro series raybestos kevlar band and a corvette servo. "
I also added a B29-2500 stall / anit balloon plate
Truck wont come out of first until 4-5000rpm under normal acceleration. If I punch it from any speed, it will hit the rev limiter and truck wont gain momemtum, it doesnt matter wether it is a 30, 50, or 70 punch. I called the shop up and they said they will look at it, do you all think it could be the TC?
Old Feb 28, 2006 | 02:50 PM
thunder550's Avatar
High on diesel fumes
Sounds like your 2-4 band is toast. When it comes out of first does it drop into 3rd?
Do you have a cooler and/or tranny temp gauge? Too much heat will kill the soft parts quickly.
Old Feb 28, 2006 | 03:18 PM
No cooler, it was supposed to be included but thats another story...no temp gauge. At normal driving, for the exeption of it comming out of first at 4000 - 5000 rmp it runs fine and will cylcle through all the gears. If I punch it from a stop it is fine. If I punch it from a roll it will just slip no matter what gear it is currently in. I checked the tranny fluid and its fine.
Old Feb 28, 2006 | 04:36 PM
Bad_Apple's Avatar
I was having that same problem..... punchin it from any speed and it would just rev up and it only got worse as I put miles on it till it died. I have built 4L65e and new PI 3000 stall going in this weekend thats going to fix my problems hopefully.
Old Feb 28, 2006 | 09:22 PM
thunder550's Avatar
When my band died I would go 1-3-4 when accelerating. Do you still have 4th gear?
Old Mar 1, 2006 | 04:48 PM
I have all the gears, It just slips like hell when I romp on it and it wont come out of first until around 4500 rpms under a soft steady acceleration from a stop.
Old Mar 2, 2006 | 10:28 PM
Red Heartbeat's Avatar
The thin plates and frictions they put in the transmissions to add clutches causes problems. the transmission frictions can't handle the heat in a high HP application and warp. Next thing you know your transmission is toast. Ask me how I know, I made the mistake of doing the 9 disk clutch. Now I am going to the blue plate special in the 3-4 clutch pack while I rebuild the whole thing again.
blownss27
Aug 14, 2020 08:27 AM
drummer0415
11
Oct 24, 2015 08:16 PM
maxspeed05V
Sep 23, 2015 10:48 AM
MikeD.
Sep 17, 2015 09:39 PM
iregret
Sep 7, 2015 01:20 PM
