ok will this work or what?!?!?
i have a 2000 ext cab short bed silverado. there is a suspension crossmemeber that links the two lower a-arms together. now on one side of the cross member the wholes are slotted for god knows why. this creates a problem where after a while the bolts come loose and the crossmember slides when u turn and makes a horrible noise. ( two bolt holes are slotted, two are not) so i used 4 washers and torqued it a 100ft/lbs like the dealer said then i got to thinking...what if i just went to a melt shop and had them fill the slotted part in and jsut drill a new hole that wasnt slotted. what do u guys think? did GM make it slotted for a reason? should a crossmember be able to move and slide back and forth like it is? any advice on how to fix this really jimmyed up idea GM had would be appreciated
Stainless Works
Apr 10, 2016 04:34 PM
atxlt
Jul 20, 2015 11:06 PM
Nimoryan
Jul 5, 2015 03:50 PM
